Tuning/chaning gear ratios
This might seem like a stupid question but is there anyway for the average everyday person to change the gear ratios on the transmission to make it faster or even more fuel efficient? Or is it something that has to be done by the dealer or the pros? The all-mighty Google has given me no answers. Thanks.
Changing gear ratios is one of the most expensive thing racers do to their transmissions.. It involves making right out CNC new gears for the trans and tailoring to the race track. That isn't happening for our trans tough.
Your best bet is to get another transmission be the; CL-S 6 Speed Manual swap or the AV6 Transmission which have different ratios vs our OEM.
Yeah most of the time the quickest way to customize gearing is through the final drive gear in the differential, which on most rear wheel drive cars isn't especially hard since the diff is separate from the transmission. However the TL is Front Drive, so its all packed into the trans-axle assembly. On top of that, most automatic transmissions are planetary gear systems which in order to adjust the gearing you would basically have to make a new transmission.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
joflewbyu2
Oct 8, 2015 11:16 AM
guyvelella
Sep 30, 2015 11:02 PM
AcuraKidd
Sep 26, 2015 04:10 PM
