Tsudo Exhaust + Mid Muffler Delete
![Arrow](https://acurazine.com/forums/images/icons/icon2.gif)
So, I have a 2002 Tl (NOT Sport) and I plan to get a Tsudo axleback, and a mid muffler delete. How loud will this be? Will it be loud enough? My budget is around 300-400 for an exhaust kit, so if you could recommend anything better please do so, or if this setup is good, please state so ![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
Also how much do you think people would charge to put the tsudo exhuast on, And do the mid muffler delete?
THANKS!
THANKS!
check this thread.
https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/2g-tsudo-sp-axleback-sound-clips-862377/
if you search tsudo axleback on here or anything like that you should be able to find plenty more sound clips, as well as reviews and such
and if your budget is 3-400, tsudo is a great buy, most people that have them love them. i think they're like 280 online, and ive heard an average of like 60 for a mid muffler delete. you should be able to install the axleback on your own its just 3 bolts on each side, but if you want it installed im not sure how much itll run you.
2 bolts each muffler no problems at all. May need to heat the bolts to remove them. Scrape all old gasket material off Y pipe before installing new mufflers. You may need new hangers for driver side muffler so anticipate that and while u wait for the tsudos to arrive go to advance auto for two of these:
http://shop.advanceautoparts.com/web...xhaust+hanger+
You'll most likely need them on the drivers side muffler. If not just return them.
check this thread.
https://acurazine.com/forums/showthread.php?t=862377
When I get the mid muffler delete done, do i need to provide the straight pipe they replace it with? If so, where should I buy it at, and also what material should it be made out of?
Just go to the muffler shop and tell them you want a mid muff delete, thats all you should say and they know what to do.
I didnt cheap out and just cut the mid muff out and replace with a new piece of piping. I did all new piping from the cat back to the tsudo's. I loved them at first but honestly now i want them a little quieter, the drone at 2-3k rpm is just annoying to me. I always have to go past 45mph and in 5th gear to let it quiet down to 1k rpm
DerrickW
11-15-2015 05:52 PM
johnpancakes014
09-27-2015 12:58 PM
