Testing waters for Random Tech cat TL & CL....
#121
New ride...Acura MDX 2013
thanks phipark, btw guys I still haven't had a chance to get that installed yet, my three sons keep me hopping so hopefully I can find a couple of hours this weekend
#123
Sippy Cup (x2)
Originally Posted by Phesto
i have the cat, my speed shop was in contact with RT and he said that they had to special order the cat because of the fittment i dont remeber the exact dispute or reason/ Otherwise i like the cat , although didnt really feeling any gain or anything. I did it because i wanted a complete new exhaust system front to back.........
#125
Originally Posted by snowman81
I always thought that we had a high flow cat on there to begin with. I know this was talked about quite a while back and most people seemed to agree that the cat on there was not really worth replacing for hp/torque gains. I'll see if I can find the thread on it but it was a long time ago.
#126
^^^^ me too,I wanted to be able to look down there and see a whole new exhaust set up .......You should at least remove that heat shield then,if u dont want a high flow cat........ I also think my car has a deeper tone.
#127
Sippy Cup (x2)
Originally Posted by mezzerTL-S
personally for myself I didn't buy it for Hp or torque gains, I bought it to have a full stainless exhaust from the engine to the muffler tips ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
#128
Sippy Cup (x2)
^^^^ me too,I wanted to be able to look down there and see a whole new exhaust set up .......You should at least remove that heat shield then,if u dont want a high flow cat........ I also think my car has a deeper tone. ![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
#129
some people have had rattles or resonace caused by the heat shield having a loose bolt/screw.....its really piece of mind i guess no one really ever looks under you car
#130
okay, so the cat is on and functioning fine , sorry that I didn't take any pictures as I didn't do the install, however what I can tell you is this... the hi flow cat is about 1/2" shorter than the stock cat (no biggie), the O2 sensor bung is in a different location so extending the wire about 6" is necessary and no CEL (again no biggie), as far as exhaust note I can notice a slightly deeper tone (me like), as far as any gains I doubt it but wasn't expecting any anyway... so far I'm satisfied and will post if there are any problems
#133
TLsu, I didn't do a before dyno so I probably won't do a dyno now... any gains (if any at all) are barely noticeable, but like I said the exhaust note has definately changed.
phipark, when the cat was off the the o2 sensor has wire (actually 4 wires)that are about 12" long and goes to a plug, so after unplugging I had some wire (20 gauge)and cut, extended and sealed them to prevent any moisture from getting in... as far as the b-pipe is concearned yes once the nuts are loosely fastened and start to tighten everything pulls together... I 'll be checking the tightness of the connection frequently for the time being to make sure that they stay tight
#134
mezzerTL-S thanks for testing this mod out. I was interested in another bolt on mod and this one had my interest. Based on your review sounds like I will pass on this one. I really don't want to cut my O2 wiring harness to extend.
#135
Not Asian
Evil Teo
3G MDX (2014-2020)
14
08-16-2020 04:29 AM
18160p8el01, 18160pgea00, 97, acura, cat, cats, cl, honda, random, review, tech, technologies, technology, tl, tsx, type
