Suspension Setup Question (yes I read) : o )
Old 04-21-2006, 02:42 PM
Doc Holliday's Avatar
Question Suspension Setup Question (yes I read) : o )
Ok just tell me if this works...
H&R Sport Springs with Tokico Illuminas and ??? Swaybar
I want a soft ride with decent handling... not to stiff
I have a box with two 10's and two amps, navi, capacitor that live back there... I figure when I'm sitting in the front at 210lbs... maybe it balances lol
I'll have to measure, but what do you think? please don't tell me about coilovers... I can't afford and I'm not really trying to race this car... I want a soft smooth cornering ride with little body lean.
I know for sure I want Tokico Illuminas
The springs... I just want to make sure I don't need a camber kit and that it's an even drop with my system and when I'm in the car
The Swaybar... I have no clue who manufactures a great bang for the buck one
and then I'm done... model numbers would be awesome
I trust and love this forum and I'll take pics when I'm done with everything...
Old 04-21-2006, 03:31 PM
I=X - optomos
optomos's Avatar
I think your going to need a camber kit regardless. You should at least include the cost of a rear camber kit into your project. The Eibach sport springs will give you a more balanced look/drop, but more then likely require a front camber kit.
The Illuminas are the way to go if you want to adjust from a stiff to a softer ride.
Swaybar-Eibach & Neuspeed
Old 04-21-2006, 03:46 PM
Tristate ViP Crew
CL Platano's Avatar
Comptech Sways, there was a group buy on them check the sponsor sales section, with H&R you wont necessarily need a camber kit but with Eibach most definately. You can get most of this stuff in the sponsor section or the black market. I bought all of my mods in the black market.
Old 04-21-2006, 05:53 PM
Cool
I read that some guy's Comptech sway broke in half !?!
Old 04-21-2006, 06:04 PM
Question
Also I do not want to buy a camber kit, if possibly... so which springs should I get with tokico illumina gas shocks?
and which sway bar is good bang for the buck and durable as well?
Old 04-22-2006, 07:56 AM
Dragging knees in
Pure Adrenaline's Avatar
Comptech sway bars have been on my car for years now and they are holding up well. I got them for like 303 shipped at the time.
H&R Sport *might* require a rear camber kit; in most cases I've seen, it didn't. But you might be one of the unlucky few who might need it. So set aside some cash for that, just in case.
Or if you really really don't want to get a camber kit, then go with the H&R OE Sport springs. The drop won't be as much, but it will still drop the car about an inch. Combine that with the Illuminas and it should be a decently smooth ride. In the corners, the Comptech sway bars should hold you up.
Old 04-22-2006, 01:47 PM
Lightbulb Now you're talkin' !
I think this is what I'll do:
-H&R Sport Springs (F-drop.75/R-drop.5)
model# 51858-55
-Tokico Illumina Gas Shocks
F-model# BU3730
R-model# BU2934
-Comptech Swaybar
model# 140-215
Old 04-23-2006, 02:06 AM
Wallace, LA
TLsu's Avatar
Tein H-Techs won't require a camber kit either. Good luck.
Old 04-23-2006, 03:06 AM
I think I'm going to go with eibach for the swaybar... It's a thicker bar
Old 04-26-2006, 01:49 AM
02 WDP type-S Navi
importvizion's Avatar
I think u meant H&R OE Sports which are the same ones for the 6th gen Accord .75F - .5R the H&R Sports are 1.75F - 1.5R....because of the shorter rod of the tokicos you'll notice it'll be just a little lower than if you ran the springs with stock shocks...
Old 04-26-2006, 03:43 PM
99 SSM Tl
MrAlex's Avatar
H&R 50103 is the way to go definitivly not the 51858 !!!
Old 04-26-2006, 08:42 PM
B A N N E D
S1CK TypeS's Avatar
i just bought the neuspeed lowering springs which has a 1.75 drop in the front, i dont remember the rear. do u think ill need a camber kit?
Old 04-26-2006, 10:45 PM
02 WDP type-S Navi
yep u do, front n back...pretty much anything 1"+ drop needs a camber kit....you don't need it, you only need it if you want your tires to last and wear evenly
Old 04-26-2006, 11:22 PM
Agean Blue Bishes
demolition_x's Avatar
the sway bar isn't really that necessary. i would do all the suspension set up and see if you like it. the illuminas are the way to go.
i love mine. car rides on rails with some help from my pro kit but you will like em.
Old 04-27-2006, 12:09 AM
99 SSM Tl
MrAlex's Avatar
sway bar do a lot on handling !! it really depend on how you drive..
With my H&R 50103 i had -1.3 negative on the rear before my camber kit .. is not that bad..
Old 04-27-2006, 01:28 AM
TL Q(
wmah523's Avatar
that's my setup, H&R 51858 paired w/ Illumina. i have no system so the car sits really evenly all around. since you got some extra weight, as MrAlex said, 50103 of H&R is the way to go...
the ride is very smooth w/ my 18"s yet comfortable w/ shock rate 2 on Rear and 1 on Front....this setup works like a charm! highly recommanded
and no camber kit needed for mine...
1fatcrxnem1
22
06-01-2018 01:23 AM
Heyzuez20
10-14-2015 07:18 AM
KillerG
09-04-2015 02:02 PM
Nicho863
09-03-2015 09:16 PM
Quick Reply: Suspension Setup Question (yes I read) : o )
