Suspension modification.
Old Mar 2, 2010 | 11:36 AM
fsttyms1's Avatar
So i finally decided to break down and spend the money on the 08 TL Type-S SHOCK ABSORBER MOUNTING RUBBER pieces (part # 51631-SEP-A01) You will need 8 of them The front and rear use the same pieces.
The are harder rubber with the metal washer molded to them as opposed to our softer rubber with separate metal washers and metal sleeve. With the stock shocks or similar replacement nothing needs to be done, with the Koni shocks the hole needs to be drilled out slightly (i used a 15/32 drill bit)
So far initial impressions are great. Much better feel with them over the stock pieces. You can order them from Heeltoe or the dealer. It will run you about 100-120$ depending on the dealer but i think its worth it.
Here is a side by side of the new one once drilled
This is a side by side of Stock vs the 3rd Gen Type-S They look much different but fit great
This is the reasoning for me replacing them. They started to self destruct and was causing suspension noises.
For those of you that are doing suspension work, DONT try to undo the swaybar end link (many break or have issues) Simply unbolt the bracket from the spindle and swing the whole thing out of the way allowing you to get the shock out of the way
Old Mar 2, 2010 | 11:50 AM
jjashaa's Avatar
Avant Garde Wheels
holy cow!~~!!@~@#%
Old Mar 2, 2010 | 12:01 PM
fsttyms1's Avatar
Yes! Holy Cow. I dont know why but all of them, even the fronts were destroyed. They were new from honda when i put the Konis in.
Old Mar 2, 2010 | 12:57 PM
TheMegalodon's Avatar
I'm a thrill seeker in my
Forgive my ignorance for a moment but can you explain what part this is exactly? What am I looking at in the engine bay pic?
Old Mar 2, 2010 | 01:17 PM
jjashaa's Avatar
Avant Garde Wheels
number 7
Old Mar 2, 2010 | 02:38 PM
fsttyms1's Avatar
Actually the pic is the rear one but yes, #7 is what the new ones replace (they actually replace 1,7,3,7,2)
Old Mar 2, 2010 | 03:53 PM
That's what I thought but wanted to be sure, thanks guys. I should look at mine come spring and see how they're holding up with the teins
Old Mar 2, 2010 | 04:20 PM
fsttyms1's Avatar
Id recommend these for any one. They make the car quicker to respond
Old Mar 2, 2010 | 05:11 PM
assclown's Avatar
2000 acura tl FPR
i'll do this once i put new shocks on, i'm thinkin about bilsteins
Old Mar 2, 2010 | 07:17 PM
JCharged's Avatar
^ Do it. I love mine
Great info Kris. I will be updating my suspension some for the upcoming road racing event in May.
Revalved Bilsteins & Custom rate ground controls.
Old Mar 3, 2010 | 08:14 AM
fsttyms1's Avatar
Sweet! I like the improved feel of them. It is a little stiffer and the turn in is quicker. (even with snow tires)
Old Mar 3, 2010 | 09:44 AM
NSXNEXT's Avatar
Ordered mine last night. Need to take out my rear TeinSS anyway cause the adjuster nuts are frozen.
Old Mar 3, 2010 | 01:49 PM
fsttyms1's Avatar
Old Mar 3, 2010 | 02:47 PM
DC3328's Avatar
Your Garage
subscribed will do this in the future
Old Mar 3, 2010 | 04:41 PM
friesm2000's Avatar
B A N N E D
just to let you know fstty, that is installed wrong , the bushing should be the other way around, so when the nut is tightened it preloads it, so that it does not move around then (take a very close look at that parts diagram btw)
so the reason for the premature failure/chaffing
and if both were like that (top and bottom), it will really move arond then
i actually had one installed backwards on mine (on one side), idk why it got like that though, but anyways i flipped it back and you can actually feel it be stiffer, especially over a speed bump at work where the fronts shocks actually seemed weak, but not now though , very minor detial, but huge effect though
Old Mar 3, 2010 | 05:53 PM
fsttyms1's Avatar
Actually it was installed right, they completely deformed and molded in the way you see them. (they were bought from napa) They were cheap and i think That is the reason they did that. The pic above is actually upside down and used to look like that the other way. All 8 of them did that. (i learned my lesson years back on my civic by putting them in upside down)
Old Mar 3, 2010 | 05:55 PM
friesm2000's Avatar
B A N N E D
that explains alot though, but still looks to have been installed upside down though
and instead of trying to make different ones work, why just not use your original ones, if you still got them
Old Mar 4, 2010 | 06:25 AM
StreetKA's Avatar
can you post a picture from a bit further way ? i still cant locate it in my mind. but i think ima do it bc i have alot of noise lately in front suspension.
Old Mar 4, 2010 | 06:59 AM
fsttyms1's Avatar
Because these new ones are MUCH better. They are a hard rubber with the washer built in. Nothing else is needed with the install of these. They dont need the metal sleeve, or the other washers. The car has a feel to it it has never had (even when the others were first installed)
Old Mar 4, 2010 | 07:00 AM
fsttyms1's Avatar
I didnt take a pic from further away. Pop your hood. Look where the strut comes thru the opening, look at the center washer/nut. This is where that rubber piece is.
Old Mar 4, 2010 | 07:45 AM
friesm2000's Avatar
B A N N E D
and btw that picture is of the REAR stut tops that are behind the rear seats, and not the front ones
Old Mar 27, 2010 | 11:02 PM
OBrechkin's Avatar
Word
[So far initial impressions are great. Much better feel with them over the stock pieces. You can order them from Heeltoe or the dealer. It will run you about 100-120$ depending on the dealer but i think its worth it.]
100-120 for each or for the whole set ?
Old May 25, 2010 | 12:43 PM
Slpr04UA6's Avatar
-------Tim-------
For the whole set of 8. 2 per shock. Very nice improvement over stock, but I also upgraded to Koni SP3's so.......
Old Aug 19, 2010 | 12:50 PM
fsttyms1,
I ordered 4 of the 51631-SEP-A01 FR. SHOCK ABSORBER MOUNTING RUBBER and plan on using them to replace the worn old stock rubber when I install my new Tokico blues.
The link below is the parts diagram for the CL:
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Question: On either side of the front fork mounting base #8, I am assuming that the washer side of the 51631-SEP-A01 faces up for the one on the bottom and faces down for the one on the top when installed??
Can you clarify at your earliest convenience.
Thanks!
Old Aug 19, 2010 | 09:53 PM
fsttyms1's Avatar
the rubber pieces go like pictured. They will appear to fit the other way but that is incorrect.
Old Aug 20, 2010 | 08:00 AM
Thanks.
Old Aug 16, 2012 | 11:01 PM
TheMightyQuinn's Avatar
Registered Nonmember
Forgive me for resurrecting an old thread, but does the 3rd gen bushing also replace #6 on the front? So it replaces 3, 4, 13, 4, 6?
Old Aug 17, 2012 | 07:40 AM
fsttyms1's Avatar
Yes. it has the metal washer molded into the top.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
lanechanger
Oct 13, 2015 10:56 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
adreano17
Sep 29, 2015 08:48 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
