Rotora BBK in the Rear!!!???
#42
For those thinking or wanting a Rear BBK the 3g guys have a discussion going on and a couple of us have been doing some research
ENJOY
ENJOY
A larger rear brake kit "could" be benificial from a bias stand point. But the major problem in adapting a brembo 2 or 4 piston caliper would be the thickness of the rear rotors. All cars with rear brembos have ventilated rear rotors. These are over twice as thick (9mm vs 20mm). Try to adapt that to a solid disc Honda rotor and you might just drop the pads out of the caliper as they wear down.
So then you might think, lets step to a ventilated rear rotor. Again now the theory of performance comes into play. A vented rotor is gonna be a bit heavier. And as we all know, un-sprung rotating mass is the ultimate enemy of performance. Plus, the rear brakes do so little work on a FWD, it's kinda pointless to begin with.
Honestly, I would still like to see someone put in the effort to put STI rear calipers onto one of these. BTW: The 04-08 Sti caliper is really the best option. The piston is slightly smaller than the TL's rear piston, which makes the prospect of a larger rear rotor more practical.
04-08 TL Rear caliper & Rotor
![](https://i.ebayimg.com/t/Centric-Parts-141-40538-Disc-Brake-Caliper/00/$(KGrHqVHJBEE+P2!6HL!BQNLwwT0cg~~_35.JPG?set_id=89040003C1)
![](http://centric.cataloglookup.com/part_images/12040061.jpg)
04-07 STI rear caliper & Rotor
![](http://www.amazingsavingsautoparts.com/images/products_all/CE/14147518.jpg)
![](http://centric.cataloglookup.com/part_images/12547023.jpg)
Interestingly, the 2G CRV has a rotor roughly the same diameter as the STI, with the same hub-register, bolt patern and similar install height as the TL. Perhaps if the internal drum is the same diameter as the TL (170mm), these might work on the TL with caliper adapter bracket.
![](http://centric.cataloglookup.com/part_images/12040063.jpg)
Wonder if we can get the 350Z Track rear rotor to work with the STI caliper or 350z rear caliper? Though this is a 14" rotor, which if were to be used i would use the 14" front
I havent been able to verify but i think the Genesis Coupe with brembos has the Drum in Hub which is a 330mm dia with 20/18mm thickness Looks like the Equus might too
![](http://centric.cataloglookup.com/Inquiry/..%5Cpart_images%5C12042101.jpg)
Genesis Coupe
![](http://centric.cataloglookup.com/Inquiry/..%5Cpart_images%5C12551035.jpg)
Equus rear
![](http://centric.cataloglookup.com/Inquiry/..%5Cpart_images%5C12051041.jpg)
Genesis Coupe
Equus rear
handsom-hustla
11-13-2015 05:04 PM
09-17-2015 09:01 PM
