other mods
Originally Posted by atran
what do those things do
Thermoblock spacers: A special gasket (thicker than OEM) that goes between your intake manifold and head, and your intake manifold to your throttlebody. It does not transfer heat like our OEM ones do, so it keeps everything up top cooler. Cooler air makes better fuel economy and more power.
Apexi NEO: This is a fuel management controller/VTEC controller. You can adjust your fuel curve, VTEC range, air/fuel ratio, ect. Basically tune the power out of the car.
Urethane Motor Mounts: They keep the motor from flexing as much under hard acceleration, and are stronger. They put more power to the ground as opposed to losing it to motor flex.
port and polish, type-s manifold if you have the TL-P
Oh and there is no point in doing the 6 speed engine swap without the 6 speed manual trans. Its the exact same motor as the type-s other than a few sensors.
besides cai and exhaust and pullys and headers is there anything else i could do besides turbo and 6 speed engine swap
[QUOTE=fsttyms1]port and polish, type-s manifold if you have the TL-P
QUOTE]
what would the type-s manifold do? cuz I saw a tl parting out not to far from me and wanted to get the lights, but if this adds some performance then I would look into that as well.
QUOTE]
Originally Posted by 02type-s
Throttle body spacer, thermoblock spacers, Apexi NEO, urethane motor mounts
How much are they?
Where can I get it?
Ps: i know those question kind of stupid.
[QUOTE=myron][QUOTE=fsttyms1]port and polish, type-s manifold if you have the TL-P
The manifold is a 2 stage manifiold. With a tune and the 2 stage actuator hooked up there will be some HP gains
Originally Posted by Rsoetidjo
How big is the different on the gas mileage and performance if I get the throttle body spacer and apexi NEO?
How much are they?
Where can I get it?
How much are they?
Where can I get it?
Also log into the CL side of the forum, more over there have these mods
The spacers come in a kit from Outlaw Engineering . You get the throttle body spacers and intake manifold spacers for $103 shipped.
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
lanechanger
Oct 13, 2015 10:56 AM
