msd ignition
msd ignition
I have an msd 6al box and blaster two coil. you think i could get these things to fit on the TL they were on a mustang last just wondering cause they are just sittin around also do they makes better cams for the TL
The TL uses direct coil on sparkplug so those wont work.
No there are no cams for the TL.
02 NBP TL-S W/Navi
no i dont think you can, seeing how the TL uses individual coil packs per cylinder. its one of the first things i looked for when i bought my TL-S. MSD doesnt make any products to fit our needs....last i looked anyways.
NGK Iridium IX spark plugs at 7 bucks each and a can or 2 of seafoam to clear all the carbon out- makes a TL run like new
Wanna pm me a deal on that msd- would fit my truck~
yeah today i changed the oil with mobil 1 and put in autolite iridiums (spelling ) is there a difference between the nkg and autolites. and is the throttle body located under the cover.
get those autolites out immediatly- like now!
NGK and denso are the ONLY approved plugs
the NGK Iridium IX outlast the denso and cost less, about 7 bucks each
The TB is located under the plastic engine cover
NO, there arent any ignition upgrades for the tl
'99 Acura 3.2TL
im runnig bosch platinums +4 on my '99 and even though people said bosch were not recommended mine work just fine, no problem after a couple of years...
T-Swzy
what about those weird metal plates that goes over your engine and is supposed to give you better and more even starts or something? anyone know what im talking about?
Originally Posted by bwebbTL
I found an ignition upgrade for the TL go onto sfx performance.com then go to parts by vehicle and select ignition. its called a SCI ignition amplifier.
02 NBP TL-S W/Navi
Fits: will not work on cars with coil packs. Acura all models 1970-1980 all models, 1980-2003 Honda all models, 1980-2000 Mazda all models, 1980-2003 Mitsubishi all models eclipse galant lancer mirage montero, 1980-2003 Nissan all models 200sx 240sx 280zx 300zx 350zx altima, maxima sentra stanza xtera /must have distributor, Subaru all models, Toyota all models, Volkswagen Jetta/GTI/Golf all models. without rev limiter
NGK iridiums or NGK Platinums are the only thing you should put in your Tl or Tl-S, the others will work but Honda uses these for a reason, Denso's are ok too but I prefer the NGK's over the Denso's. As far as ignition upgrades go, you can probably use some kind of a voltage amplifier off a similar car such as the HKS twin power ignition amplifier and modify it to work on the Tl. Theres really no need to upgrade since the stock coils will provide sufficient spark to the average Tl drivers setup. Maybe if you fully built the motor and added a bunch of boost then you might have to start worrying about ignition break-up.
very true i never really plan on really digging into the motor oh and i did end up taking the autolites out and switching them with NGK i did get like ten more miles per tank. cool thanks for the advice
Acura604
20
08-05-2017 12:55 AM
ExcelerateRep
10-14-2015 08:20 AM
