Legend Dual piston caliper with Legend pads?
Quick question. If you upgrade your 2G Tl calipers with the dual piston calipers from the Legend, will the TL's pads still fit or will ou need to use the Legends brake pads?
Think about that one for a second...
No, you don´t use the Legend brake pads as the Caliper Bracket must come from the TL (The bracket holds the brake pads)...
You re-use your TL pads and when you buy your pads you will buy them for the TL, The Legend Caliper will work with the TL pads.
