J32A1 in sandrail....
Hello, I am new to this forum and the j32a1 motor. I purchased a sandrail with this motor, it has a turbo kit(7psi) on it but other than that it is stock. I am wondering what other bolt on parts I can get for it to get more HP and TRQ...like i said all I know about the motor is that its a j32a1 out of an Acura...Thanks
Received 2,329 Likes
The following 2 users liked this post by Ken1997TL:
ABP_04TL (02-27-2012),
CLtotheTL32 (02-26-2012)
AZ Track Whore
actually very common to use J engines in off road stuff.
check out www.j32a.com, probably a better place to find answers to your questions.
arent the A1s out of the 2nd gen bases? i think iirc they are a LOT easier to tune because of no DBW... Im sure you could do open headers or something of that sort and maybe PnP the manifold
Turd Polisher
^ Correct.
A Co-worker of mine has a sandrail with an older J35 from an Odyssey with a small supercharger attached, thing looks and sounds beastly.
If I ever see it in action, I will most definitely film!
I got the Shifts
try the 2nd generation forum. the j32a1 came in the 1999 acura TL. there are a few parts to make more power but since you are turbo i wouldn't suggest adding any aftermarket parts. take it to a tuner and make more power by increasing boost. the j32a1 has 9.5 compression so it is by far the best engine to boost in acuras v6 range
licopico (02-27-2012)
https://acurazine.com/forums/garage/...-licopico.html
Heres a link to the garage it wouldnt let my click on the pics cause ima new member or something....
donchicago48
08-02-2015 04:54 PM
narkotsky666
11-08-2011 03:58 PM
