How do I use sport shift?
once you pop the shifter into ss mode, up is to shift up and down is to downshift. nothing really to it. basically the same as a MT except for the fact that there's no clutch and there is a little delay when you shift and when the car actually shifts.
Originally Posted by fsttyms1
there is no secret to it. All it does is give you control over when it shifts. Just remember that your in it and dont forget to shift.
Originally Posted by Hitlayers
Funny you mention that, it's happened to me a few times then I shift, can this hurt the car in anyway? letting it get too close to redline??
I only use SS when driving on steep roads or when im about to run against somebody. Dont see the point of it during regular driving.
Originally Posted by myTaLizaS3.2
ohh.. so when you are about to redline, do you let go of the gas pedal and then shift?
good sh*t. The car's a beast in SS mode. One more question. I turned of the traction control and it seems to me like it frees up more torque. Not sure how to explain it but that's what it feels like. How does that work?
TCS applys the brake when the front wheels are moving faster than the rear. applying the brake while you are accelerating slows you down. its only really usefull if you are in the rain snow or ignorant.
Thats the good thing bout VSA..Ive had mine work goin 80 before...BTW 1st gear in SS shifts just like it was in regular D5. It is a little more on the sporty side tho...the only gears you have to shift in/out of is 3rd, 4th, 5th
Originally Posted by Blazin_TL
unless you have a 99. 99's dont automatically shift into 2nd you need to do it manually or it will just redline.
Originally Posted by MurkyRiversTL
Yup and in the 99 even if you turn off the TCS it still comes on if your wheels start to spin...... at least it does in mine. Is there any way to really turn it off? Or is mine a special case?
Thats what the switch is for, its to turn it off. Whats the point of having a switch turn it off only to come on when your tires spin?
I honestly couldnt tell you what the point would be of having a switch if it doesn't work, I didn't make the fuckin car. Maybe my car is just giving me a pretty light to look at.
No shit that's what the switch is for. That's why I asked if mine was a special case.
Well if you know thats what the switch is for why ask the question? Obviously there is something wrong if you turn the system off and it still activates. It shouldnt be like that (unless the 99s are different- which i dont think they are) It could be a problem with the switch. When you push it does the light on the dash come on?
I know what the button is for. that is the reason why I asked if mine was a special case..... meaning that I dont know if anyone elses does that and if not is there something wrong.. When I do push the TCS button the light comes on. When I push it again the light goes off. When I take off from a start and my wheels start to spin the light begins to flash. Just like I had stated before.
Oh shit now I feel like a dumbass. Do you mean to tell me that when the light is "ON" on the dash that the TCS is "OFF".
LOL DAMN IT!!!!! Sorry for the attitude earlier. I fell like such an idiot. Obviously I didn't know what the hell I was talkin about. Thanks for puttin up with me. And sorry for stealin this thread. Now I can go and spin tires without having to worry about the stupid TCS. Thanks fsttyms1, all you've ever done was help me, and I appreciate........... dont mean to get all sentimental on ya.
Originally Posted by Leo Type-S
i have a question.. is there any way to shorten that delay of shift? a grounding kit or am i totally wrong? or a stand alone ecu or something?
i've always wondered about this... lets say im going a good 40mph in 4th then i want to floor it w MAX power while in ss mode. how far should i downshift? would it hurt the tranny or engine to downshift all the way to 1st?
You can experiment without fear (althought the downshift and upshift limit speeds are in the owners manual) Try slipping down from 5 to 3 or 2 above 80 oops I mean
The computer will not downshift if it knows that will cause an overrev in the requested gear. On my 2001 TL, the gear number flashes if trying the impossible, for 3 seconds I believe, and stays in a safe gear. Drop a few mph and try again - you may be in the range now- thats what brakes are for, slowing down the car. D/S in SS should be so you are on the torque band for exiting the next corner.
You can click that SS switch all you want, but the all knowing black boxes will keep the engine safe. We also have fuel cut-off switches when you hit rev limit or other throttle control depending on your cars year and model. Its good to know when these things occur so the time you have to realllllllllllllllllllllly use the power- you know its limits
When you come to a stop or very slow, like getting off the freeway, the SS wil go to 1st gear and then auto shift itself to 2nd, about that time you hear the engine and remember to shift up again- its time for 3rd and you are back to work!
Hey Kris
As usual you have the exact numbers
The original question posted was could he go into 1st gear, my reply was about the relative safety of trying to downshift to 2nd at speed, it simply wont and thats something owners should know. 96 you say...., will see how that works at Thunderhill next track day. Had to postpone one due to new trans break in period Least the trans was free and the motor mount only 150 installed!
TL
TL
Hey Kris
TL
TL
just a quick related question...
When I was going from a very small local road onto a major highway (idk, NJ roads suck sometimes), I floored it. I don't think I hit redline (maybe 6-7K in first or second), but the car didn't shift up when I wanted it to, and it was only when I got off the gas, did it go up. Is this just the delay or normal or should I be like going to redline?
SidhuSaaB
05-30-2020 12:40 AM
neuronbob
23
07-16-2019 10:48 AM
