How to Convert to NSX Ft Calipers????
In 702, 808 in Dreams
Hey guys.
I remember i saw REV's set up but i was wondering how this conversion is done?? I know i can find a set of NSX Front Calipers but i wanted to know which year it is taken off of. this way i can try and find what i need next.
i know i would need some stainless ft lines but would i use them from a NSX or a TL??
Lastly would this Caliper bolt right up? or would i have to get the NSX brake brackets? i would not mind going for this caliper next since its a 2 piston caliper rather than a 1 large like the OEM ones. PLUS it says NSX on it heehee. but yeah any info would be awsome to help get me started on this conversion.
thanks j
thanks j
Originally Posted by PenancE
they bolt right up to the knuckle on the stock tl calipers, put ss lines while ur at it
ohh one last question which year would you use it from? im assuming from the newer years since its more up to date with our TLs. like at least from the 2000 up model???
i might try and get the rebuilt ones and try thoughs out. since they are way cheaper than finding a set at the junk yard
heres a diy
https://acurazine.com/forums/showthr...caliper+legend
the thread maker doesnt know what year for nsx, id go for a higher year
The brakes were changed for the 1997 model year.
Larger front and rear brake rotor diameters and rotor thickness. The bracket and
the rotors are the major change. Front caliper pistons went from 40mm and 34mm to 40mm and 36mm.
http://www.nsxprime.com/FAQ/General/changesbyyear.htm
08_UA7_Gr33k
02-11-2016 02:17 PM
