future modifications and fixes
Old Mar 10, 2011 | 06:39 PM
cgmc's Avatar
i recently got a 2002 tl type-s and im new to all of this stuff.
If you could comment on what im about do with this car i'd be grateful.
in order of what i have to do
1. replace left headlight (the right headlight was previously replaced so the left headlight looks hella dirty) ~$100
2. replace front rotors (slotted rotors) and brake pads ~$150
3. delete mid-muffler ~$50
4. buy and install f&f1 coilovers ~$600+$200
5. corner balancing and alignment ~$200
6. rims ~$800
7. tint ~$150
for a total of ~$2250.
Old Mar 10, 2011 | 06:41 PM
jjashaa's Avatar
Avant Garde Wheels
wetsand left headlight, polish it up.
800 for rims is cheap. i hope you're not getting some funky ass rims.
Old Mar 11, 2011 | 12:12 AM
Karanx7's Avatar
Unregistered Member
1. Don't buy new headlights just because their dirty. You can clean them back to brand new looking.
3. Ripping you off
5. I recommend you get a lifetime wheel alignment. It's less than $200, and it usually pays for itself after 2 uses. I've saved a loooot of money.
+Intake resonator delete ~$Free
Old Mar 11, 2011 | 11:47 AM
01tl4tl's Avatar
corner balancing, also know as corner weighting, is way different than firestones lifetime alignment
with adjustable coilover shocks the OP plans to install- you put a scale under each wheel and adjust the actual height of the shock spring assembly until the weight is where you want--as weight transfers to opposite corner
That gives the car perfect balance for things like auto-x racing
It also leaves the car sitting a little funky as balanced is not the same as looks level~
01tl4tl's Avatar
put 2500 away for that trans rebuild
Old Mar 11, 2011 | 11:51 AM
01tl4tl's Avatar
if the headlight lens has mositure inside--you need a new housing or DIY repair this one and reseal
if just cloudy get a headlight restoration kit- 10-20 dollars and attaches to your cordless drill
see our diy for more info
Note: it may have 1 new bulb with that new housing,,compare light color and output
always want to replace in pairs so they stay equal
Most of gen2 is ready for bulbs or on new ones already
Old Mar 11, 2011 | 04:16 PM
cgmc's Avatar
thanks guys.
i just restored my headlights using turtle wax's headlight lens restoration kit for $8.99 at autozone. SWEET. its not perfect like the new headlight, but 95% similar. niceEEE
Old Mar 11, 2011 | 04:20 PM
cgmc's Avatar
when do u think my transmission will go out. it has 81000 miles on it and it has been brought to the dealership for the transmission recall.
Old Mar 11, 2011 | 06:03 PM
Karanx7's Avatar
Unregistered Member
OH, I see. Thanks for the info. I don't know anything about suspension, yet.
Old Mar 11, 2011 | 08:16 PM
01tl4tl's Avatar
the recall has nothing to do with the clutch wearout failure,,, which you are right in the mileage zone for
starts happening around 60...mine went at 68,,other get 80-100..maybe a little more
a rare few are well into the 100s with original trans
ck for blue bolt heads on trans, meaning warranty replaced unit
change 3 qts fluid, external filter and shift selenoids
see diy threads for help
Old Mar 11, 2011 | 08:18 PM
01tl4tl's Avatar
if first treatment made headlight lens better- do it again,,
the plastic will look worse at first, then get clearer and cleaner as you go
Old Mar 12, 2011 | 02:42 AM
cgmc's Avatar
Ook thanks. aww man, i dont wanna spend money replacing the transmission yet. hopefully it'll last. did it cost 2500 to fix?
Old Mar 12, 2011 | 10:13 AM
01tl4tl's Avatar
typical repair cost reported on here range from a low of 1800 (may have been trans only -no install), a norm of 2300-2800 and high of 3400,,those are `installed` numbers
all depends on how many bad parts are inside- with auto trans, there is just no telling without tearing it all apart and start cking and measuring things
acura gets 4 grand +++ to sell and install a rebuilt unit of their own as comparson
Old Mar 12, 2011 | 10:15 AM
01tl4tl's Avatar
see the main `Tranny Failure Thread` for description of 2nd and 3rd gear clutch pack issues and early wearout
avoid using SS mode to do high rpm downshifts into 3rd and 2nd = to prevent excess wear
Old Mar 12, 2011 | 10:20 AM
01tl4tl's Avatar
if you have a late sale 02 (sold in 03) there is a chance its still under the special trans warranty of 7 years 9 months or 109kmiles (some Vins with odometer error court case get 114.5 indicated miles) of course its which ever occurs first time or miles and is from date car first sold new- acura care has that date on file
register with acura care as new owner and ask about that,, and any `open recalls`need to be completed--
airbag inflator is the most recent recall, and still has cars not come in for it!!
1 800 382 2238x5 usa cars
1 888 9acura9 canada cars
Old Mar 12, 2011 | 01:34 PM
cgmc's Avatar
sweet thanks bro.
cgmc's Avatar
learned alot
Old Mar 12, 2011 | 05:03 PM
01tl4tl's Avatar
lets hope for a freebie trans~ or a long healthy life of the present unit!!
Old Mar 12, 2011 | 07:52 PM
03tLsNBP's Avatar
MechEng
install the coilovers yourself. its too easy to give to someone else.
Old Mar 12, 2011 | 07:59 PM
friesm2000's Avatar
B A N N E D
corner balancing is a little bit involved then most people do...
first major sign of failure on mine was at like 93k, with being able to get 120k of it, before replaced it (but 5th gear was basically shot though, not the norm though)
it will get better, but will still never be as good as the newer one though
LMFAO, using actually probably made my trans last longer due to not being in 5th as much as normally (but as said not the normal failure point
Old Mar 16, 2011 | 05:52 PM
Toms02TL's Avatar
yo i went 2 the shop 2 get my resignator taken out and the guy said not 2 do it bec it wont really give me anything performance wise and theres a chance it will backfire this true?
Old Mar 16, 2011 | 05:56 PM
friesm2000's Avatar
B A N N E D
most people do it for the sound then anything
as far as back firing LMFAO, not going to happen VERY easily on a fuel injected car, without a tune (and ALOT more mods)
Old Mar 16, 2011 | 10:07 PM
TRafalik's Avatar
Thats when I would tell him to shut up and do it anyways.
SidhuSaaB
May 30, 2020 12:40 AM
mugen_kid
Nov 13, 2015 10:38 PM
Sep 17, 2015 10:16 AM
JnC
Sep 11, 2015 06:06 AM
