Front Sway Bar Bushing replacement question
Old Aug 9, 2015 | 03:36 PM
wwlc21's Avatar
I am looking to replace the old sway bar bushing/bracket/new bolts (NOT the links). I have been searching online and read 10+ posts in the forum but it's still unclear whether you need to lower the front sub-frame to undo the bolts for the bushing brackets?
(some threads mentioned about a redneck method that due to unable to undo all bots on the bracket (without lowering sub-frame), you'd just bent the bracket with one bolt on, replace bushing and bend it back) but this isn't my preferred method as I am replacing all bolts, bracket and bushing.
My ultimate question is:
1. Do you need to lower Front sub-frame to get complete access/removal of bushing bracket and bolts?
2. If yes, is new alignment necessary? (some members say yes and some no)
I understand that those bolts tend to be seized but shop is asking $80 labour to replace it and I feel that's asking too much if this is only a bolt on/off job. (ie. without lowering front sub-frame)
Thank you in advance.
Old Aug 9, 2015 | 07:55 PM
Skirmich's Avatar
1.- No, Redneck method works fine.
2.- No
Old Aug 10, 2015 | 02:47 AM
wwlc21's Avatar
Thank you for you reply, I actually finished the job myself today within an hour.
To confirm the answer of my questions:
Q1. you DON'T need to use redneck method! maybe i misunderstood the intention/when to use the redneck method. it is just a bolt off, replace, bolt on job. please see my instructions below for how i did the bushing replacement job.
Q2. NO new alignment is needed since you are not touching any other suspension/steering/sub-frame part.
So I decided to do a write up on this:
https://acurazine.com/forums/perform...-2g-tl-934760/
Old Aug 10, 2015 | 02:51 AM
Skirmich's Avatar
Which is basically what I said.
No = the answer to your question "Do you need to lower Front sub-frame to get complete access/removal of bushing bracket and bolts"
"Redneck method works fine" < an actual fact.
Redneck method is used when you use an over-sized bushing instead of the stock one.
Thanks for the writeup! might come useful for members.
Onyxthecat
Oct 18, 2016 02:05 PM
drone619
Jan 26, 2016 07:09 PM
Heyzuez20
Oct 14, 2015 07:18 AM
