Front camber kit
Old Nov 15, 2013 | 03:34 PM
Eip539TL2002's Avatar
2002 Acura TL-S
Front camber kit
So am I the only one that's burning though tires like crazy after lowering my tls I bought a front and rear camber kit but the front wheels are still out of alignment so what I'd like to do is get a better front camber kit, any ideas on what the best camber kit is?
Old Nov 18, 2013 | 08:35 AM
fsttyms1's Avatar
How low are you? You would have to have a TON of camber to be burning thru tires. Are you properly aligned as far as toe?
Old Nov 18, 2013 | 12:53 PM
FlacoJ's Avatar
I finally went ingalls they are now $200 on ebay, instead of burning through $300 worth of tires every 6 months, be warned they still need a little shaving to not hit the frame
Old Nov 18, 2013 | 05:45 PM
HairyMonkey019's Avatar
For front's I got SPC camber kits. How many degrees do you have? I'm not even burning through my tires yet, I have like -1.5* ish
Old Nov 19, 2013 | 10:22 AM
fsttyms1's Avatar
Im running a little over 1deg in the front and 1.7 in the rear and just got 40k out of my summer tires
Old Nov 19, 2013 | 12:23 PM
Excelerate's Avatar
Former Sponsor
How much is your camber off? What front camber kit do you have?
Old Dec 6, 2013 | 10:23 PM
03 tls nc's Avatar
Camber will not wear your tires out near as fast as improper toe settings. It would be helpful to know your set up, how many miles, and have you checked any of your other suspension components. Our cars are getting some age on them and the rubber OEM bushings are not going to be performing at there best.
Old Feb 5, 2014 | 03:39 PM
2002 Acura TL-S
Thanks for all the reply's i took my car somewhere else to get the alignment checked and the Toe was way off, the place i took it to at first i guess didnt know what they were doing which sucks but my tires should be wearing alot more normal now
james357
Feb 13, 2016 02:37 PM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
08 NBP TL
Sep 8, 2015 08:49 PM
Sep 4, 2015 08:03 AM
nuldabz
Sep 3, 2015 05:49 PM
