Flex pipe noise on new DC Headers
Old 02-26-2012, 06:38 AM
Oakroadsteve's Avatar
After my son installed DC Headers on his 03 TLp I noted that it made the same wonking noise at certain points that my CLs made after I put on XS Headers. That was solved by wrapping the flex pipe.
Doing the due diligence on this site before this install, I was under the impression that the DC Headers don't have this issue but it sure sounds like the flex pipe. We have access to a lift and wrapping the headers is easy enough but it is a band aid fix that needs to be redone periodically.
Has anyone else had that issue with their headers??
Old 02-26-2012, 10:38 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
are they installed properly? IE is the rear hanger on? were they forced into position or did the bolts line right up? Any misalignment on them will cause a slight stress causing that.
Oakroadsteve (02-26-2012)
Old 02-26-2012, 11:36 AM
kill you till you die
yeedatoy's Avatar
Are all the motor mounts good? I worried about installing headers without fresh mounts because the excessive play may cause added stress on the headers, causing cracks or flex pipe issues.
Old 02-26-2012, 11:58 AM
The hanger was not properly affixed. Excellent suggestion....Thanks!
Old 02-26-2012, 12:02 PM
Yes the mounts are good. I had them checked when we bought the car. Thanks for the suggestion. The mounts are starting to wear on my Type S and that could affect my XS Headers...
Old 02-27-2012, 04:03 PM
It turns out that that the bolts connecting the j pipe to the headers lined up but not perfectly. They needed to be forced slightly into place. Could that cause the noise and if so what can be done about it?
MrHeeltoe
20
02-23-2023 01:54 PM
SexyRL
4G TL Problems & Fixes
08-19-2016 10:03 PM
xsilverhawkx
10-05-2015 11:00 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Flex pipe noise on new DC Headers
