Engine oil?
Old Aug 26, 2010 | 08:34 AM
troper24996's Avatar
Engine oil?
First oil change and I'm not sure what kind of oil synthetic or regular is in there. I wanted to do synthetic change.
How cam o tell the diff???
Old Aug 26, 2010 | 10:44 AM
Nola2000TL's Avatar
Does it matter what is currently in there? If you want synthetic, buy it and use it.
Old Aug 26, 2010 | 11:01 AM
Actually, I have heard a lot of different crap, that's why I'm all confused.
-All i want to do is just get the Damn Synthetic and high flow filter change it and be on with my life.
*All the A-holes at the Parts store say I need to slowly change over if I was not already using synthetic....Which is why I half to make this post!
Old Aug 26, 2010 | 11:16 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
If you want synthetic, you are more than welcome to use it with no ill side effects.
Dino and synthetic are interchangeable. But, I'd just stick with dino oil and a cheap filter and save money. It'll be more than adequate.
Also, there are SO MANY threads on this already on this forum, that all you would've had to do is search, and they would've shown up.
Old Aug 26, 2010 | 11:21 AM
fsttyms1's Avatar
Dont listen to the morons at the parts store that tell you you you have to change it slowly. Just buy it and change it. You cna switch back and forth as you want. You can mix it you can do what you want.
Old Aug 26, 2010 | 08:56 PM
jperdoch's Avatar
I have tried both in my 03 Tl-S. No difference in gas milage so now I am back to regular oil. I change it every 5,000 miles (I have 4 cars, 2 Hondas and a Toyota and it is easy to remember that way). I have 140,000 on it and it runs great. I did the same in my last Acura (88 Legend) and had 210,000 on it when I sold it.
So I do not see a real benefit on synthetic in my experience except for one thing. I have been told that the Toyota tends to 'gunk up' on regular oil, so I use synthetic in it.
All the Hondas get Valvoline 5W20.
Old Aug 29, 2010 | 07:23 AM
Thanks synthetic it is
Old Aug 29, 2010 | 07:51 PM
gold2003tl (90)'s Avatar
2003 TL-p
i used reg Valvoline 5w20 on my last change along with a purlator pure one filter, i am satisfied with it. car runs great, and smooth. see how long it lasts and how it looks at my next change, if i like it, ill stick with reg Valvoline, its cheap too.
Old Aug 30, 2010 | 12:27 AM
tc5280's Avatar
Flagship Aspec
MaxLife and VPS works great for me
Old Aug 30, 2010 | 01:45 PM
BrooklnzBadB0y's Avatar
I use Mobil 1 synthetic all the time and my car runs great
Old Apr 1, 2011 | 10:15 AM
tomf's Avatar
03 Type S - 153,000 miles
I just switched to the Pennzoil Ultra - ultra class full synthetic. Does anyone have any experience with this ? I just realized I change my oil way to frequently - every 3000 miles.
Old Apr 1, 2011 | 10:30 AM
Karanx7's Avatar
Unregistered Member
Lol, 3000 is overkill. I just switched to Royal Purple. I can't really tell the difference over the Dealership Honda oil. I get $5 oil/filter changes at my dealership, so I might just go back to them.
Old Apr 1, 2011 | 10:38 AM
dan lazer's Avatar
~~~ SKY'S THE LIMIT ~~~
so i use castrol gtx high milage 10w 30 with a K-N oil filter----what do you guys think of this-----GOOD or BAD
THANKS GUYS
Old Apr 1, 2011 | 10:49 AM
Karanx7's Avatar
Unregistered Member
I'd stick to 5W-20 or 5W-30, but it really won't make much of a difference.
Old Apr 1, 2011 | 11:08 AM
2003 TL-p
^agreed, no need to run 10w-30
5w-30 or 5w-20 will be fine.
castrol gtx high mileage wont hurt anything, that stuff is little on the thicker side of 30, its good oil. Of coarse a full syn would be better.
Old Apr 1, 2011 | 07:58 PM
totaledTL's Avatar
Have used both 10w-30 & -40, no issues, no discernible difference.
Old Apr 2, 2011 | 09:24 AM
fsttyms1's Avatar
Except for in cold climates its thicker and takes longer to get to vital components. You arent getting better protection from a thicker oil.
Stick with what the manufacturer recommends 5w30 or 5w20 (the later can be used in 99-01 as well)
Old Apr 2, 2011 | 11:07 PM
kdawg8526's Avatar
13.2@106mph G37 RWD Sedan
using 5w20 full synthetic Q-horsepower oil with fram synthetic filter. i can change my oil every 12000k with the synthetic filter.
Old Apr 3, 2011 | 12:10 AM
Karanx7's Avatar
Unregistered Member
You CAN change your oil every 50k if you want. That doesn't mean it's healthy for your car. Acura states that the oil needs to be changed every 7.5k, regardless of what oil you use. But then again, they also say to change your filter only ever 15k.
Old Apr 3, 2011 | 12:27 AM
kdawg8526's Avatar
i meant 12000kms which is about 7000miles
BoricuaTL
Apr 8, 2016 01:08 PM
Frathora
Sep 28, 2015 11:29 PM
pizokk1
Sep 17, 2015 09:29 AM
ghuns
Sep 16, 2015 04:26 PM
datadr
Sep 12, 2015 09:12 PM
