do CL front seats fit in the TL?
Old Mar 2, 2012 | 02:08 PM
cdn_rider's Avatar
VIP TL
i searched but cant find any answers, does anyone know?
Old Mar 2, 2012 | 05:54 PM
fsttyms1's Avatar
Yes
Old Mar 2, 2012 | 08:36 PM
cdn_rider's Avatar
VIP TL
lol good answer! appreciated
Old Mar 2, 2012 | 08:59 PM
02type-s's Avatar
-Arsenic-
Yep, looking for some myself
Old Mar 2, 2012 | 10:26 PM
03tLsNBP's Avatar
MechEng
Yes the brackets will fit but the wiring connectors may not be the same.
For example, the 02 TL Type S seats do not have the same connector as the 03 TL Type S seats. I know this, annoyingly, from personal experience
Old Mar 6, 2012 | 10:55 AM
cdn_rider's Avatar
VIP TL
fuck, i cant find any pics of the cl-s plugs, anyone know if theyre any different?
Old Mar 6, 2012 | 12:48 PM
fsttyms1's Avatar
Just repin your existing connector to the new seat. All you need to do is figure out what wires do what.
Old Mar 6, 2012 | 01:06 PM
03tLsNBP's Avatar
MechEng
^ Yeah that proved to be a waste of time for me. You can take the entire seat apart and swap the cushions instead. It took me about 3 hours to swap both seats. That included taking a break for food and beer.
Old Mar 6, 2012 | 04:32 PM
cdn_rider's Avatar
VIP TL
^^so do you have tl-s seats or cl-s seats?
Old Mar 7, 2012 | 02:02 PM
03tLsNBP's Avatar
MechEng
i have TL-S seats but CL-S seat cushions should fit on the TL seat frame.
Old Mar 11, 2012 | 07:02 PM
AznWay's Avatar
I just got done installed some TL/CL ( not sure how to tell different between the 2 if any) type-S seat. I also did what 03tLsNBP did some what. I just swap out base of the seat frame b/c the ones i got was very rust dirty compare to mine. Yes the wiring is very different. Since i have 99 i took out all extra wiring an SRS side air bag out. I use main connect for car to seat to hook every back together. The passenger side was very easy with everything connect. For the Driver Seat i had 1 female connect left did not fit anything. Only problem i have now is my driver will not go up an down for height adjustment. ( no biggie)
I love the way Type-S seat hug your body compare to "P".
Any real different in rear Type-S seat an can CL rear seat fit TL? I like way CL rear has divider (maybe my next mod )
Old Mar 27, 2013 | 07:32 PM
cdn_rider's Avatar
VIP TL
so bump. i never did do this because i didnt want to re-pin anything, however, since the 99-01 TL's are the same and so are the CL's, im wondering if the 01 CL seats would need re-pinning, anyone know?
Old Mar 27, 2013 | 07:43 PM
assclown's Avatar
2000 acura tl FPR
I don't think so. They have memory seats.
Old Mar 27, 2013 | 08:52 PM
cdn_rider's Avatar
VIP TL
good call, thanks.
Old Apr 4, 2013 | 08:08 AM
fsttyms1's Avatar
Just take the time to repin them. Its VERY easy. Ill post the pinouts later if you want.
Old Apr 4, 2013 | 08:49 AM
cdn_rider's Avatar
VIP TL
if its that easy, maybe i will, i just didnt have the slightest clue on repinning, so post them up!
Old Apr 5, 2013 | 02:03 PM
fsttyms1's Avatar
I copied all years so Depending on your year car and the year of seats you have you will have to match up to the correct year harness.
TL
CL
Old Apr 5, 2013 | 02:10 PM
MilwaukeeDave's Avatar
Is there a possibility of adding the memory function to 99-01? Would it require only seats and door panel? I really hate when the wife or anyone for that matter changes my seat. And please don't say keep her out of the TL, I already try lol.
Old Apr 5, 2013 | 02:17 PM
cdn_rider's Avatar
VIP TL
if you switched out the door panel, you would have to switch out all of your switches, including the lock switch that has the memory function on it, because its longer than the 99-01 version.
so fsttyms1, these are all TL model years or the same for CL model years as well?
edit: i have a 2000 and a TL im looking at is an 03, which ones would i be looking at?
Old Jul 14, 2013 | 08:17 PM
fsttyms1's Avatar
There is MUCH more to it than that. There is a control unit for it AND its also part of the ECU.
first and 2nd one and last one.
Old Feb 17, 2014 | 08:52 PM
Gabru678's Avatar
Do you guys know if there is a difference between the CL-P and CL-S seats?
Like would the S have bigger bolstering?
After googling and looking at pictures I cant really see the difference.
Old Feb 18, 2014 | 06:43 AM
3.2TLc's Avatar
Hey GAbru678, have ya tried checking the " CL " forum..... those guys probably could better assist ya with CL seats and stuff !
Old Feb 18, 2014 | 04:23 PM
Gabru678's Avatar
Hey 3.2TLc
Yea but I thought I might as well ask here on this thread first.
But I'll head over there now.
Thanks!
Old Feb 18, 2014 | 08:34 PM
Gabru678's Avatar
wrong thread. My bad
Old Nov 12, 2014 | 11:04 PM
Gabru678's Avatar
Hey guys!
So I ended up doing this swap and everything works great (Power, recline, memory, airbags hopefully) But for some reason I am not getting heat on the drivers side back and I have the Seat Belt Light on. Any indication as to why?
I would really like to get the heat working on the back moreso than anything really.
It was an 03 CL seat into an 03 TL.
PortlandRL
Sep 14, 2015 12:01 PM
08 NBP TL
Sep 8, 2015 08:49 PM
truonghthe
Sep 7, 2015 11:17 PM
leerbgdup
Sep 6, 2015 11:01 PM
