DIY Rotors & Pads **HOW TO w/ PICTURES**
#81
Yes same way, make sure that the E-brake is Not on, check the e-brake pads also when you have the rotors out. When you put the rotor back in, you might want to adjust the e-brake so it's not too loose, but not drag on too tight.
#83
![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
#84
so i can barely stop on the interstate during rush hour. seems like i'm just about at my limit & have to purchase new pads/rotors soon. if $ is a problem at the present time, can just the front brakes/rotors be changed then the rears at a later(not too late tho) time, or is that a no no when it comes to this shit?
also, what's the main difference between the slotted & drilled & slotted (just performance? or longevity)? obviously, i'm assuming just slotted rotors are better than blanks..
#86
cool. thanks..
#88
A good degreaser works very well, Many good wheel cleaners and a little soaking and elbow grease work great too!
#89
same situation here. Could you tell me the drill bit size? Thanks
#93
7th Gear
This DIY was a lifesaver! I have all the pics printed and followed them step by step. I never attempted breaks before, but this made it easy. I had some issues with rust (my TL came from PA, and the snow/salt got the best of her!) but other than that, it was smooth sailing.
#95
So, I had this thread bookmarked but I didn't read it before actually replacing my rear brakes and rotors today (had a friend to help me). The process was exactly the same and I learned a bunch! Only tricky part is getting the nuts and screws out, especially if you have rusted parts like my car!
I didn't flush the brake lines because I didn't know I should do such a thing. I guess I'll do that when I replace my tires.
Anyways, Helpful writeup, thank you.
#96
Of fcking course as soon as I start my pads + rotor replacement I come back to this thread and photobucket is being shitty
photos are all blurry...
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
