Custom Cams
Former Sponsor
I have already developed a set of cams. I am just waiting on dyno #'s from CleanCL. If you want you can contact me and we can discuss some info. I can get you a set and you can be the guinea pig. PM me.
Originally Posted by type-s09
yeah with the increased airflow the car will be out of whack in the tune...
13.2@ 107 on Street tires
well i have to get them first...i already have an AFC Neo so im good to go on the tune...my main concern is the stock valve train being able to handle the new cams...i dont want to have to replace springs and retainers
Originally Posted by fsttyms1
The cams wouldnt be that much more aggressive, so i wouldnt worry about it ( the VTEC lobe already is is an aggressive cam lobe so its ready for it). All you would be doing is slightly changing the duration.
so if the vtec lobe is already aggressive enough what is the purpose of getting the cam? when accelerating exept for the launch the car stays in vtec anyways...please explain for me
Changing the duration if there is enough clearance could yield some more hp in different areas?? All there is is speculation UNTIL some are made and dynoed.
Former Sponsor
o ok...CleanCL is trying to sell me his cams...good or bad idea?
yes i understand this...i was going to install it at acura but i dunno...this is my plan....find a used head and send it to king to get a full head job including valves, springs, and retainers...i am going to send a cam along with the head so they can build the head around the cam...i want the cam to be aggressive so it will probably have to have a built head to be strong enough to hold the cam...im not spending $1000 dollars on something i dont even know works in the first place...i would rather have someone well known as king to do the work for me...i know i will at least get 20whp out of a built head and cam...
Jul 16, 2017 07:33 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
Sep 25, 2015 06:14 PM
