can u mix synthetic w/ standard oil?
i was a 1/2 quart low on oil and added that much of oil not remembering i just switch to synthetic oil in march. will this effect the engine and performance or is it basically oil is oil?
You mean you last changed your oil in march to syn, or you started using syn in march but have changed it since?
But to answer your question yes you can mix them, BUT if you are on extended change intervals I wouldn't mix them unless an emergency or you plan on changing it soon. It won't hurt it, but it will reduce the long interval properties of the syn.
to syn or dino, ....dunno ?
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
How many miles are presently on your TL and what is the frequency of miles between oil changes ?
Check for any apparent oil leaks or seepage. Did you put in a full 5 qts. @ last oil & filter change ?
IBankMouse
06-13-2020 12:53 PM
lanechanger
10-13-2015 10:56 AM
09-25-2015 06:14 PM
