cams
Old Jan 5, 2008 | 11:57 PM
bwebbTL's Avatar
cams
there has to be aftermarket camshafts for the 3.2L i mean they put that engine in hondas and acuras but i sure as hell cant' find them anywhere i'm pretty interested in learning how to swap them out.
Old Jan 6, 2008 | 12:38 AM
red00tl's Avatar
I don't think there's such a thing available on the market.
Although I am no engine expert, the impression I get from reading up all the sources available in our forum is that our engine is pretty much tuned to its highest performance potential at the factory.
Beside the usual set of bolt-ons, there is no other economically feasible and readily available performance enhancing modification available for a 2G TL.
The only exception seems nitrous, but that's something else entirely.
It's only good for going straight and it can only be pernicious to your already fragile transmission.
Old Jan 6, 2008 | 09:14 AM
fsttyms1's Avatar
There aren't any. Our vendor excelerate had a set made but he never got a member(with a stock motor) to install them and have a before and after dyno to see if the grind would give us gains.
Old Jan 6, 2008 | 11:21 AM
bwebbTL's Avatar
well i'm a member i my car is 1 hundered percent stock lol i'll ask him about it.
Old Jan 6, 2008 | 01:30 PM
fsttyms1's Avatar
Its not free either. Its like 700 bucks
Old Jan 6, 2008 | 04:41 PM
sbuswell's Avatar
I need 2 more gears
why would a stock motor be required if there was a before and after dyno done?
Old Jan 6, 2008 | 07:52 PM
fsttyms1's Avatar
To give an accurate representation of the gains
Old Jan 6, 2008 | 08:14 PM
Gee-TR's Avatar
having some custom cams ground is another option if you have the cash to do it.
Old Jan 7, 2008 | 02:06 AM
bwebbTL's Avatar
have you tested them or had dynoes done. pm me with the price that would be sweet.
Old Jan 7, 2008 | 07:26 AM
fsttyms1's Avatar
Thats what the vendor had done. Its not cheap.
Do a search on the CL side of the forum. All the info is there.
Old Jan 7, 2008 | 12:04 PM
bwebbTL's Avatar
oh i thought you said you have some custom ground cams.
Old Jan 7, 2008 | 12:36 PM
NSXNEXT's Avatar
You could go with TypeS cams if you're driving a TLP.
Old Jan 7, 2008 | 02:27 PM
bwebbTL's Avatar
ok thats do able is there any websites the sell the type S cams
Old Jan 7, 2008 | 02:28 PM
bwebbTL's Avatar
any idea on the what the power difference would be on the type S cams
Old Jan 7, 2008 | 04:22 PM
fsttyms1's Avatar
http://www.acuraautomotiveparts.org/...catdisplay.jsp
dont expect huge gains, these motors arent like old pushrod fords and chevys that can get a bunch out of a cam because we already have a aggressive cam that does in vtec what most big grind cams do.
Old Jan 7, 2008 | 09:52 PM
bwebbTL's Avatar
i found the cams on there only 244 dollars for both kinda cool. i know i need more than just the camshafts anything else such as seals or anything else i should get with the cams
Old Jan 8, 2008 | 09:28 AM
MurdaZ's Avatar
thats a waste of money and a mod imo..
Old Jan 8, 2008 | 09:49 AM
NSXNEXT's Avatar
Cylinder head cover gaskets will certainly need to be replaced.
Factor in several hundred (i'd guess $400) for install. You should also purchase an air-fuel controller as the stock ecu will limit the gains with the new cams.
I'd say you're looking at $1000+ for everything.
Old Jan 8, 2008 | 10:00 AM
fsttyms1's Avatar
And so are the 400-1000 dollar exhausts people put on to gain 2 hp. There are certainly far cheaper and most likely yield alot better mods out there, But if your looking to squeeze every last bit out of it why not try. I do suggest getting a NEO or E-Manage and having the car dyno tuned afterwards
Old Jan 8, 2008 | 10:18 AM
bwebbTL's Avatar
ight ight i get the point cams arent' in these cars anyting like in muscle cars. o well learn something new everyday
Old Jan 8, 2008 | 11:02 AM
NSXNEXT's Avatar
np, just pointing out to the masses that it's not as simple as just throwing a set of cams under hood and poof, instant HP.
Old Jan 8, 2008 | 11:49 AM
fsttyms1's Avatar
Old Jan 8, 2008 | 12:37 PM
bwebbTL's Avatar
tru dat
ExcelerateRep
Oct 14, 2015 08:20 AM
kmarqueling
Oct 3, 2015 01:14 AM
Papa Roe
Sep 26, 2015 11:45 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
V12 Inspire
Sep 10, 2015 04:46 PM
