CAI install questions, need help FAST!!!!
Old 01-12-2006 | 09:57 PM
sbuswell's Avatar
I need 2 more gears
Exclamation CAI install questions, need help FAST!!!!
I am installing my CAI right now and everything is on. I have two hoses one long(1 foot or so) and other shorter 6inches or so. The two coolant hoses that connected to the stock airbox are just sitting there and don't know what to do. Can someone guide me please?
P.S. vacuum lines are connected to the intake already.
Old 01-12-2006 | 10:04 PM
demolition_x's Avatar
Agean Blue Bishes
which intake?
Old 01-12-2006 | 10:06 PM
sbuswell's Avatar
I need 2 more gears
it's a Bomz CAI, I need help rerouting the coolant hoses, their instrcutions suck. I know its a cheap CAI, but everything fits fine. I just need help with the coolant hoses.
Old 01-12-2006 | 10:07 PM
sbuswell's Avatar
I need 2 more gears
BTW it is like an AEM CAI
Old 01-12-2006 | 10:14 PM
Agean Blue Bishes
you got to take the engine cover off in the front. there should be a coolent hose from the throttle body to the front of the engine. you have to remove the metal piping with 2 pipes attached fromt he engine. the hoses replace that. i just helped some one else with this search under my name in december i helped him out it had some pics and stuff
Old 01-12-2006 | 10:16 PM
snowman81's Avatar
Sippy Cup (x2)
Not quite sure if it's the same for then 99 as it is for the 02. I just connected the hoses whichever way I felt was best. It's not going to matter which hose goes where because they are both going to the same place, they just come from someplace different. I am assuming one of them is the vaccuum hose though. If you're still not 100% you can go to cardomain.com (or someplace similar) and look at pics of 99 TL's that have CAI and see if you can tell how they have their hoses hooked up.
Old 01-12-2006 | 10:29 PM
sbuswell's Avatar
I need 2 more gears
can I just connect the two coolant hoses that went into the stock airbox together?
Old 01-12-2006 | 10:31 PM
MrAlex's Avatar
99 SSM Tl
plug the two hoses (the two that where plugged into the little radiator in the air box) togetter..
Old 01-12-2006 | 10:36 PM
sbuswell's Avatar
I need 2 more gears
that's it? I have the vacuum lines hooked up so I just need to plug the two coolant hoses that were in stock airbox together and I'm done? are you sure?
Old 01-12-2006 | 10:38 PM
MrAlex's Avatar
99 SSM Tl
yeah im sure if you whant i can take a picture of my intake maybe.. add me on your msn if you whant it !
Old 01-12-2006 | 11:25 PM
sbuswell's Avatar
I need 2 more gears
everything is connected and I took it for a 5min run and it sounds awesome! one problem is the mounting bracket doesn't line up with anything. it is resting underneath the horn. how can I secure the intake so it doesn't move?
Old 01-12-2006 | 11:28 PM
Agean Blue Bishes
sheet metal screw? idk how it doesn't line up with any thing. the brand name intakes use a bolt that the airbox was screwed to.
MrAlex's Avatar
99 SSM Tl
you dont have a little rubbet to put under the bracket ?
Old 01-12-2006 | 11:31 PM
sbuswell's Avatar
I need 2 more gears
yeah the is a rubbet(if that is what they are called) it is like a rubber piece with threaded bolts on both sides. where would I mount this?
Old 01-12-2006 | 11:34 PM
MrAlex's Avatar
99 SSM Tl
umm where the stock air box was screwed before.. just on left of the hole
Old 01-12-2006 | 11:40 PM
sbuswell's Avatar
I need 2 more gears
does the mounting bracket face down? any pics? As you can tell this is the first CAI I have installed and the instructions might as well have not been ther because they were useless. also does filter face downward or forward?
Old 01-13-2006 | 12:08 AM
Agean Blue Bishes
just look around where the bracket lines up. there should be a threaded hole some where along where the bracket can go.
Old 01-13-2006 | 08:46 AM
sbuswell's Avatar
I need 2 more gears
The bracket does not line up with any holes, it is close but not close enough. right now the bracket is resting underneath where the horn is. Can someone show me a pic of the bracket mounted and where it is mounted or another way to secure the intake so it doesn't move? Thanks for all your help guys!
Old 01-13-2006 | 11:14 AM
dchondasport's Avatar
2006 TL ASPEC
http://wizardsworks.org/chod/acura/cai/
Old 01-13-2006 | 11:40 AM
fsttyms1's Avatar
I would say its not installed correctly or its not made correctly. Its supposed to line up with the holes that mounted teh factory airbox.
Old 01-13-2006 | 11:46 AM
sbuswell's Avatar
I need 2 more gears
I'll have to mess with it some more and see if I can get it to mount properly. Also does filter face forward or downwards?
Old 01-13-2006 | 11:51 AM
snowman81's Avatar
Sippy Cup (x2)
That depends on the design of the intake. The AEM faces forward and the Injen faces down...so it really depends on how your intake was made. It may be a little easier for people to help you out if you are able to post some pics up. That would give us an idea of what you are dealing with. Good luck.
Old 01-13-2006 | 12:25 PM
sbuswell's Avatar
I need 2 more gears
I think it is supposed to point down because that is only way the bracket will be parallel to the spot it needs to be mounted to. I think I just need to pull the intake away from the TB a little as it is just about flush with it now.
Old 01-13-2006 | 01:09 PM
snowman81's Avatar
Sippy Cup (x2)
I checked out the BOMZ Racing website and didn't see any CAI's for a TL. Are you using the one for the Accord? That may be why it doesn't match up perfectly. I am sure you can get it to work, you just may have to do a little modding to mount it.
Old 01-13-2006 | 02:01 PM
sbuswell's Avatar
I need 2 more gears
is there any other suggestions to mounting it, other than using mounting bracket, any other suggestions
Old 01-13-2006 | 09:16 PM
sbuswell's Avatar
I need 2 more gears
well I jerry rigged it. I actually took off horn, took off metal piece underneath it, then placed mounting bracket under that and the metal piece on top of that, screwed it down really tight and put horn back where it was before. Actually doesn't look that bad and intake isn't wiggling around, only bottom piece moves a little, but I doubt anything can be done about that. also I disconnected battery for 10mins and took it for a run and it very loud, strong sucking sound. sounds very sporty. I felt a small power difference on the highway. in the high rpm's my car did pull a little harder. On the highway it also sounded like a bad-ass V8. overall not bad for 50.00 and if it breaks, who gives a shit. I will know if it does and change back to my stock airbox or get a new intake before any damage can be caused.
Old 01-14-2006 | 03:59 PM
sbuswell's Avatar
I need 2 more gears
thanks for dealing with all my BS, I have never installed an intake before and basically had no instructions at all and installed it at night and the mounting bracket does not line up right so I had a lot of things going against me. I did manage to secure it though. I had to use a large metal clamp and secured the intake near where the mounting bracket was. Now it is firmly in place probably more so then if I were able to use the mounting bracket.
Old 02-06-2006 | 02:22 PM
Mike_McCready's Avatar
Does anyone know if i can use my stock hoses with my AEM intake? I just got it second-hand and it didnt come with hoses (or i overlooked them in the box ) If I can't use the stock hoses, can someone give me an idea of what i will need to buy at Home Depot to use for hoses?
thanks in advance
le^2
02-18-2021 11:44 PM
hues10
1G RDX (2007-2012)
09-07-2016 04:47 PM
Skirmich
09-15-2015 07:41 PM
DiamondJoeQuimby
09-10-2015 12:40 PM
Quick Reply: CAI install questions, need help FAST!!!!
