Best Replacement Fans OEM or High Performance 2001 Acura TL 3.2 (Base)
Hello,
I gotta get my Engine Fans Replaced only 1 of them currently works after i just picked up my Car from the shop
(yes i know i need to have them both running) 2001 Acura TL 3.2 (Base)
What Brand are the Factory OEM Fans? What is the CFM Rating of the OEM Fans?
I just had the Mechanic Replace Engine and Transmission Mounts, Water Pump,Timing,Belt,New Hoses,Thermostat,New Upper and Lower Radiator Hoses,Radiator Denso 221-3213(Pretty Much a OEM Radiator), AC Compressor and New Switch added to make AC work since OEM Part is no longer made, That is all the work that was done
However they neglected to Notify me i need to replace my Engine Fans while my Car was with them for like 3 weeks I mean C'mon guys why didn't you just call me and tell me hey bro you need a New Engine Fans since we already have it in our shop we can remove the old ones and install new ones, Anyways I am now shopping around for Replacement Fans
What Brand are the Original OEM Engine Fans? (There are 2 of them) What is the CFM of the OEM Original Engine Fans? they are Electric of course.
Would it be even better if i just got maybe a High Performance Set of Electric Engine Fans instead of just getting OEM Engine Fans?
I am in a High Desert State 7200 Feet above Sea Level we are in the 80s,90s during the summer, some days in the Summer we go over 100 Degrees
Recommendation of Brands and/or Models of Engine Fans?
Something that will Plug Right in to the Existing Electrical Fan Connectors and not require i guess new Fan Electrical Connectors to be Installed(that would be a pain)
TL88
08-10-2023 02:14 AM
