XLR8 Engine Torque Damper vs New OEM
Has anyone ever compared a known-good OEM ETD to XLR8's? The ETD on my new to me 08 TLS is obviously shot as the engine feels like it is always flopping back and forth between the mount straps as you accelerate/decelerate/shift. It is annoying to say the least. Visual inspection of the mounts do not show any cracks, tearing, or leaks. I hear MANY good reports of people having this same issue and going straight to the XLR8 ETD and having good results; however, I have yet to see one report of someone having this issue and replacing their OEM ETD with a new OEM ETD. As much as I like going straight to modifying to make better, I'd like to understand how different the XLR8 damper feels from a new OEM damper. Anyone have any firsthand experience?
According to the XLR8 website, it appears they have zero in stock for $149?
Shop XLR8 Performance Products on XLR8Performance.com
If that's the case, just opt for the OEM, #16 below, and call it a day to stop the 'flopping back and forth between the mount straps' before that continuous action trashes, even further, what's left of your rear mount.
Engine Mounts (MT) for 2008 Acura TL | Acura OEM Parts
The engine NVH (Noise Vibration Harshness) mitigation strategy on our cars in stock form include what appear to be VERY soft engine mounts for mitigating sound/vibrations at rest and light throttle/cruising speeds, engine rock stops/straps that bolt ontop of the mounts that rigidly limit engine rocking motion during moderate/heavy accelerations, and an engine damper to smooth out the rocking motion of the engine, preventing sudden impacts or jolts as the engine rocks quickly towards the stops during quick accelerations/gear changes. The beauty of the damper is that it allows the engine to rotate and vibrate freely with small inputs (smooth) and to significantly soften fast motions (smooth). The tradeoffs that could be noticed would be if the damper does not slow the engine enough to prevent the engine from banging against the limiter at the extent of its travel, and the rock distance from stop to stop ids quite large, causing sloppy/disconnected feedback to the driver during starts and shifts.
The XLR8 Damper is more of a rocking limiter than an actual damper. The rubber bushings within are compressed against the outer wall, offering some resistance to motion, at the expense of increased vibration, but not with a dynamic response or force that a true damper would. The beauty of the XLR8 unit is that it significantly limits the engine travel, allowing the engine a much smaller window of rocking motion, lessening inertia, lessening impact, and integrates a rubber bushing to help absorb some of the impact, again at the expense of increased vibration. All of these traits increase perceived tightness and feedback during starting and shifting. I would assume that the XLR8 damper restricts the motion of the engine to an extent that the original stops/straps are no longer ever in contact which leads me to an area of potential concern. The stock rock limiters/stops/straps are quite robust with stout pads on the engine mount bracket that contact stout rubber padded straps that are heavily bolted to the motor mounts. There are 2 of these assemblies, one on the front mount, one on the rear mount. Comparing the hefty structural design and ultimate strength of the OEM engineered rock limiter to the relatively tiny XLR8 limiter, makes me wonder if it is now a relatively weak link. I also question if it will cause added stress to the XLR8 damper mounting points, causing fatigue or other failure. Perusing the threads here, I have not come across any accounts of failures. Has anyone had any issues using the XLR8 Damper?
I only see the rear one listed on the 08 TL-S parts diagram.#12 rear engine damper assembly includes the bracket & hardware and #16 just includes the damper, sleeve and hardware?
Now, my CL-S six speed has a front and rear and unfortunately they are discontinued. Though the #16 damper for the 08 TL-S could possibly be used as a rear substitute on the CL.
Engine Mounts (MT) for 2003 Acura CL | Acura OEM Parts
This might be something to consider when you receive your new XLR8 and install?
Good Luck!
Did you go back to OEM after your NRG broke? If so, how would you describe the driving difference between the 2?
When the NRG damper worked, it did its job well enough.
I never noticed a difference between the two, other than the OEM damper actually lasting longer than a year.
I recall having a discussion with Eric (Euro-R_Spec_TSX) about whether he had an OEM damper or an aftermarket one on his TSX - he stuck with the OEM torque damper saying that in working form it's sufficiently stiff. I think that's a pretty glowing review of the OEM damper.
I personally jostled with whether to get an OEM damper or an aftermarket one and I chose the XLR8 one because I was sticking with OEM mounts otherwise and wanted a reduction in engine movement. The XLR8 damper is also much cheaper than an OEM replacement if I recall correctly.
