6 speed swap...coming soon
so i hav a 2000 tl....giving som problems..i fell like instead of spending money on it when its gonna blow anyways somtime..why not get stick swap since i luv driving wit a clutch anyways....so tell me what u guys think...
05 3.5 tl-s engine n trans
guy selling it is askin for $3500...too much or good price.....
what else would i need....my mechanic told me to put this list together..we want to get good parts...but also looking for reasonable prices...if i can get some help i would appreciate it
05 type s harness
05 ecu type S (he is working on one possibly better for J series)
brake pedal
clutch pedal
stick + cables
ebrake + cables
clutch pump
axles
i feel like i need more tho....what am i missing...
05 type s harness
brake pedal
clutch pedal
stick + cables
ebrake + cables
clutch pump
axles
bwahahahaha. that harness isnt gunna work in your car.
get the 2nd gen type-s engine and u can use and 6 speed v6 tranny from honda
if u want a 3.5 u can stroke the 3.2 using the rl pistons and make more power than a 3g.
use the richie v6 harness and save yourself time and money.
use the search button to find the parts u will need.
my thread has a COMPLETE parts list. down to the bolts needed
either way you are probably looking for about 3500- 4k on the swap and i think for that 3.5 engine is way over priced.
like phee said those 05 harness wouldn't work on your TL
all the pedal, shifter and the ebrake will probably cost you around 1K if its all new parts
damn jc....i came bac from vaca...my car jus didnt seem rite...im still riding wit that messed up oil pan...doesnt leak tho like it use to...im losin faith in this car...only thing that would revive it i think is this swap....i wont be doin any labor... hav you heard of Always Fast Action (AFA) well thats where i always take my car for the not so diy... he chargin me a g plus parts....
phee...i read that richie v6 thread....alll 148 comments...doesnt seem to look good...im still wit this engine ...and i dont get how its trickin the ecu its a AT5 ... what about when u put it in 6th gear...whats the ecu thinkin then ...
havent really read your thread...so much reading....i jus wish i went to one page n it says it all..lol...but no ones here to hand out goodies rite..thats fine...ill get to my researching...
you spent 2300 on parts aside from the private sales..you didnt state how much you got the av6 for and you did the job yourself...its better when u are the mechanic..
you saved 1000 on labor that i cant run away from...love tools n grease but just dont have the knowledge...
im not knockin on u ... i jus feel that is my easy way out...unless im totally wrong...
and what harness would i use then??
3.5 6spd...... 3500
rest of part.... 500
labor........... 1000
total........... 5000
am i nuts?
Your numbers are completely off...
my 6 speed cost me $1150
Clutch/flywheel $750ish
Brake/Clutch Pedal from junkyard $200
I spent $750 on "rest of parts"
Richv6's harness (x)
A bunch of other minor things
I'm at $5000 as well, but you should do some serious research before you begin with this project.
Phee knows what he's talking about, he's already done the swap. These trannys are interchangable with the jseries motor
6 Speed Accord (no lsd)
03 Cls
04-08 tl
If you want more power, supercharge the car down the line. Cause if you allocate the price of $3500 for engine + tranny. Tranny cost $1k so take the other $2500 and find a used or save for a new ctsc.
03 Cls
04-08 tl
From my knowledge (as in im not 100% sure) the mounts from the 3g and the 2g dont match, hence this swap has never been done. I am not 100% sure, but if you can do the swap... you have bragging rights for first 3g 2g tl.
edit. I'm not sure if there was a type S in 2005
if its 07 then it seem right but i wouldn't use 3g motor cuz it probably wont fit or you cant even close your hood. correct me if im wrong. and currently im doing the 6 speed swap
all the parts - 1600 (all brand new)
2g type S motor - 1250
05 TL 6 speed tranny - 1000
richie module - 500
XS header - 250
Total - 4600 CAD
but good luck with your swap =)
richie module - 500
XS header - 250
Total - 4600 CAD
richie module - 500
XS header - 250
Total - 4600 CAD
richie module - 500
XS header - 250
Total - 4600 CAD
for sure, i was quoted more for my simple engine swap(which is why i did it myself with some help), i was surprised to see just a thousand for his. i hope its someone he really trusts or has been friends with for a long time cuz hes gonna be taken for a ride with that "quote"
im not sure if the mechanic knows this....he does do swaps almost everyday...but mostly civic... he told me if i dont get the engine that he would n den he would drop it in a voupe or a bubble....this is the mechanic u go to when u need custom shyt done ..like a turbo for our car he would hav it ready in 3 days..so im thinkin he quoted me 1000 cuz we are friends n he is ready to mod the mounts....but ill giv him a call to make sure...
so i was talking to the AFA (the mechanic)... i told him about the mounts..that there not be a direct fit...he said not a problem he would work with it...i jus need type-s mounts....
harness issue:
i told him about the richie v6 harness...he said could be an option ..but rather work with the cl-6....so then i asked him how bout finding a cl-s motor n trans..so now he is on that....
cls motor n trans with a cls ecu n harness..or a
07 motor n trans with a cls ecu n either harness
he wants to change the ecu no matter what swap i do because the tlp is restricted
i countered 3000 for the 3.5 in case he cant find something...
any inputs
harness issue:
any inputs
jc. what im saying is that the 3.5 from the 07 is too expensive.
the harness from the 07 will not fit your car
u can keep the harness thats already in your car. buy the richie module. its 500 shipped
buy the 2003 automatic TYPE-S engine. this one will fit in your car and will work with all the harnesses in your car.
BUY the 2003 cl-s tranny, 2003-2005 accord 6 speed tranny or the 2004-2006 TL 6 speed tranny.
all of the trannies bolt right onto the 2nd generation engines and richies module handles the ECU. it works, how it works shouldnt be your concern. thats proprietary information.
my swap was cheap because i found the parts myself. u just want to sit back and let some mechanic charge u for labor and rip u a new one by upping the price on parts
my ENGINE was 380 dollars
my 6 speed was 600 dollars because i SEARCHED for it. i spent my time and dedication to find it.
and i read ever single page of every single thread. im no mechanic either, but i learned how to do it by research. nobody handed me shit when i did my swap so you shouldnt expect the same.
if you really want a 3.5 liter engine, then buy the 3.5 RL pistons and an oddysee crank and put it in the type-s engine.
it will STILL come out to be less than what your mechanic is quoting you.
if youre still apprehensive about the swap, then bring it to my shop down here. i can usually do it for under 3k.
i get you 100%....i hav been researching... havent really found anytin around my area...but thats not keeping me from stopping...in PA theres alot of tranny deals...so im hopin ill find one b4 my car gets toast.... D5 flashed on me once..turned it off out of panic...turned it on and nothing since..but i rather be safe den sry stuck on a highway..
but that's the best out in my area so far
when i did they had sold it already
