300hp
Old Oct 11, 2007 | 07:57 AM
philly fresh's Avatar
Its good to be FRESH!!
300hp
would that number be attainable for under 2000. if so whats parts would i need
Old Oct 11, 2007 | 08:02 AM
CleanCL's Avatar
not a chance for under 2,000
Old Oct 11, 2007 | 08:07 AM
c0v3rr1d3's Avatar
100 shot off nos should get u there for well under 2000, not that i recommend that, but people have run 75 safely
Old Oct 11, 2007 | 08:23 AM
how close could i get then
Old Oct 11, 2007 | 08:47 AM
fsttyms1's Avatar
not very. To do it safely, You will need the SC with HBP and every other mod there is.
Old Oct 11, 2007 | 09:23 AM
S1CK TypeS's Avatar
B A N N E D
300 to the crank can be reached with all the bolt ons. 300 to the wheels you'll need all the bolt ons and s/c or cutom turbo, or in my case 75-100 shot of nitrous.
^thats on a TL-S not a TL-P
Old Oct 11, 2007 | 10:17 AM
CleanCL's Avatar
i doubt you would be at 300bhp even with all the bolt-ons unless you went to 3.5L
Old Oct 11, 2007 | 11:52 AM
02type-s's Avatar
-Arsenic-
At the crank it is. Def not to the wheels tho.
Old Oct 11, 2007 | 01:24 PM
S1CK TypeS's Avatar
B A N N E D
u gotta be pretty damn close to 300 crank if not over.
TL-S = 260
headers = 20ish
cai = 7-10
pullies = 10ish
spacers = 5-10
Old Oct 11, 2007 | 01:37 PM
02type-s's Avatar
-Arsenic-
TL-S = 260
headers = 20ish
cai = 7-10
pullies = 10ish
spacers = 5-10
Also, a guy on here had his Type-S tuned with the Apexi NEO and gained like 12 on the dyno. Exhaust is good for about 5. I have heard Iridium plugs and a grounding system can be good for 1-2 but hey, its 1-2 more than b4 lol. 300+ crank is very possible with bolt-ons.
Old Oct 11, 2007 | 02:01 PM
CleanCL's Avatar
first of all, the original stock 260hp would not be under todays standards, you have to figure it according to the WHP recorded.
the most i have ever seen a n/a auto put down is about 230whp, given that, and given 20% drivetrain loss, that puts it at 287.5BHP... trust me... on the 3.2 and an automatic, it will be VERY hard and cost a lot more than 2,000$ to get to 300bhp
Old Oct 11, 2007 | 02:34 PM
iforyou's Avatar
You'll Never Walk Alone
well these people are talkng about the earlier standards since the car was made back then(ie, 260 rated hp when stock). Obviously they know that with the new SAE standards and/or whp, it's not close to 300. But it will be around 300 crank hp using the old standards.
Old Oct 11, 2007 | 02:46 PM
S1CK TypeS's Avatar
B A N N E D
Snowman dynoed at 240whp without a vafc and thermoblock spacers. hes the 2nd one on the TL side to dyno 240whp. i thought it was more than 20% drivetrain loss
Old Oct 11, 2007 | 02:56 PM
CleanCL's Avatar
240 is very high, i wouldnt trust that dyno, do you know what corrections were used?
btw - you can't say "well according to old standards its over 300hp" thats BS. just use the WHP run on a dyno and figure it out.
but i dont know what drivetrain loss actually was, 20% is pretty high, but i wouldn't put it past that it's more like 25%, by your logic i'm making over 333hp =]
Old Oct 11, 2007 | 03:05 PM
S1CK TypeS's Avatar
B A N N E D
i dont know anything more than this dyno sheet. this is Snowman81's dyno sheet. Types-09 also put down 240whp
Old Oct 11, 2007 | 03:16 PM
CleanCL's Avatar
and what were all of his mods? i would take that graph with a grain of salt
Old Oct 11, 2007 | 04:15 PM
dreem1er's Avatar
deal with it
under the new hp ratings the 02-03 tl-s has about 240-245, so even with every bolt-on, a tune, and vafc the power would be just under 300.....also that bs of 20 from headers no way, those "dyno proven" numbers are always bs.....when they do those test the car is pulled three times and they get the lowest hp rating and then they pull the car three times with the headers and take the highest hp rating, which is how companies get these crazy numbers, same goes for intakes, exhaust.....cars are not as restricted as they once were, so changing something like the exhaust doesn't do as much as it used to,
Old Oct 11, 2007 | 04:58 PM
JpnSamurai's Avatar
[cars, anime]= Japan
so how much gain would you say from headers? Im thinking about getting XS (yeah I know cheapest possible option... lol)
Old Oct 11, 2007 | 05:22 PM
dreem1er's Avatar
deal with it
real hp would be around 10-15.....
Old Oct 11, 2007 | 08:45 PM
fsttyms1's Avatar
Ill add one more to my list to get over 300WHP.
6 speed conversion.
Old Oct 11, 2007 | 09:11 PM
iforyou's Avatar
Then it really depends on how you look at it right? Some people prefer comparing using the old standards, some like the new standards...imo nobody is wrong here, I say the method that makes you happier is the right one.
Old Oct 12, 2007 | 12:57 PM
dreem1er's Avatar
deal with it
technically your car is making the same hp under the new/"more accurate" rating, the only thing is that people fail to realize that if your model car production was stopped before the new ratings were put into place they never went and retested em.....i.e the 3.2tl...it was no longer being made there is no reason to waste money and test it under the new hp rating.....which is why people get confused,
for instance the new accord has 244 under the new rating, but it can take out a tl type s......
Old Oct 12, 2007 | 02:28 PM
CleanCL's Avatar
because a 2g tl-s isn't making 260bhp
Old Oct 12, 2007 | 06:41 PM
well at the crank then. intake, header, exhaust, pulley. would gain me how much on a TL-p.
Old Oct 12, 2007 | 08:42 PM
'03TL-S's Avatar
oh it's even harder for you with a TL-P. you might as well change it to a 3.5L 6-speed conversion with all the bolt-ons and maybe you'll get it.
Old Oct 12, 2007 | 08:54 PM
Hockeyman's Avatar
slobalt defender
buy the ebay ghetto turbo kit, under 2g's and will give you all the power you need for the 10 minutes it works before it breaks.
Old Oct 12, 2007 | 10:21 PM
your funny. i was just wondering if it was obtainable (300hp) cars plenty quick for me just want it faster. im guessing subconciously speeding tickets fascinate me. cuz ive got 2k to spend on go fast parts. would love to find an s/c, 1500 for wheels, and ive already bought my oem lip kit, comptech springs i got from a buddy, spc rear camber kit, and tl-s wheels.
Old Oct 12, 2007 | 11:29 PM
hairything's Avatar
moddin the TL-P? Yea, I was thinkin about that too on my '03 TL-P w/ headers, intake, and pullies. Although I've read in the forums that exhaust really doesn't do much 'cause our TL-P/TL-S are already free flowin enough.
Old Oct 12, 2007 | 11:42 PM
fuck it then. ill spend it at the bar then and drive back home slow. i need a 2jz tt supra.
Old Oct 13, 2007 | 12:14 AM
hairything's Avatar
hahaha, that's what I'm thinkin....around $500 to $600 for both intake and headers for like an extra 20 to 25 hp? Can you guys really feel the difference for all you TL-Pers?
Old Oct 13, 2007 | 07:17 AM
sbuswell's Avatar
I need 2 more gears
you will feel a noticeable difference with 20-25 extra HP, that's a 10% power increase on the TL-P which would be noticeable in any car.
Old Oct 16, 2007 | 01:49 PM
Juliet's Avatar
Littlest Pirate
its doable.. u can built a turbo setup and put down 100hp. 2k is a decent budget and it definetly could be done with some careful shopping and knowing where to look for parts. for a few hundred bucks, u can buy a inexpensive t28 type turbo thats good for 350hp or more, use muffler tubing to rig up the intercooler and turbo plumping, skip the expensive fuel management eletronics and use mechanical fuel regulators and a mechanical boost controller, hit the junkyard to pick up a mk3 supra intercooler for less then $100, and finish it off with a cheap blow off valve.
2k for 100hp isnt a difficult task. theres nothing that says it has to look good or be made from new parts. if u want a nice looking setup thats gonna be reliable and consistant, then youll need a bigger budget. the others are right on that.
Old Oct 16, 2007 | 05:19 PM
00 acura tl's Avatar
Inspired
for the tl-p it will be hard to reach 300hp
type s intake manifold, Throttle body
CAI
headers
oe spacer
ur pulleys
cat back
with a 55 shot nitrous i guess you will be good then
Old Oct 16, 2007 | 05:32 PM
Juliet's Avatar
Littlest Pirate
can lighten the car for free too. it will FEEL faster without costing a dime. the less weight its pulling around, the less HP it needs to move the car. and the more of it u can feel.
you could have extensive head work too... smoothing the combusion chambers, having the valves fitted to the ports, having all the flow areas polished, get a custom ground cam.
one muscle car trick is to lighten the engine internals as well... lighter connecting rods and a lightened crank will reduce rotaing mass and "free up" HP. basic engine theorys revolve around engines losing power through friction areas, so making the motor work less to overcome the friction is one way to get of the power to the ground instead of being lost on its way to the wheels. work like that is more advanced and goes beyond simple bolt ones as well as need to be preformed by a machine shop to do the work
Old Oct 18, 2007 | 11:38 PM
3TL's Avatar
3TL
Honestly, I just say face the facts down the long run. If you don't care about your car 100shot of nitrous. $2000.... Might as well save a couple thousand more and SC charge it. That just my opinion
Old Oct 19, 2007 | 03:21 AM
im leaning in that direction unless i get a wild hair and turbo it like dirtyjohn. since we are like no more than 1 mile away from each other
Old Oct 19, 2007 | 08:23 AM
MyPearl02's Avatar
so the only way that any of us are gonna make that 300 mark is to have real deep pockets and be smart.....? shit im out im broke and im not smart
Old Oct 19, 2007 | 08:39 AM
Inspired
yah but 240 to 260 whp is enough for our car. 300hp is way to much, without a sc, turbo or nos you can't get 300hp and you don't need deep pockets, get the parts slowly.
Old Oct 19, 2007 | 04:33 PM
Juliet's Avatar
Littlest Pirate
u can do it without forced induction... but its not cheap. it requires a master engine builder who understands how to milk out every last HP from custom ground cams, custom cut pistols, lightened internals, ported heads, etc.
people have been getting huge numbers without forced induction since they started racing cars. its not impossible to do it with a TL... just not nessicary. way too expensive and without purpose other then bragging rights.
Old Oct 19, 2007 | 04:44 PM
02type-s's Avatar
-Arsenic-
Like this?
