2 stage intake swap onto 99 tl-p
Old 06-06-2011, 11:39 AM
Dankwgn420's Avatar
iv been looking all over the forum and can't find anything about this. had anyone done the 2 stage intake swap on to there tl-p and if so what goes into doing it any info will be awesome thanks
Old 06-10-2011, 01:03 PM
Dankwgn420's Avatar
really no info whats so ever on if this is something that can be done it seems to me that the two motors are identical except for the intake, computer, and cams
Old 06-10-2011, 01:27 PM
The Dumb One
Rockstar21's Avatar
what two motors?
Old 06-13-2011, 12:57 AM
Dankwgn420's Avatar
between the j32a1 and the j32a2
Old 06-13-2011, 01:07 AM
Unregistered Member
Karanx7's Avatar
Yea, it's been done. Just search around. And it's J32A1 and J32A2.
I'm assuming your talking about the intake manifold? It should bolt up fine, but you won't actually get the gains of the second intake opening up without a controller. I think you could keep it open, but you'd lose low end torque. Something like that.
bowlgers (01-15-2012)
Old 06-13-2011, 10:22 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
There are a few that have done it. NSXNEXT has. The 99 has different injector rails that need to be swapped out as well. You will also need a RPM switch to activate the 2nd stage.
https://acurazine.com/forums/showthr...&highlight=rpm
Dankwgn420 (06-14-2011)
Old 06-13-2011, 02:09 PM
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
Yeah lower intake manifold (a.k.a. injector bases) need to be swapped as well as fuel pressure regulator, fuel injectors. It's not just simply swapping in the new upper intake manifold.
Read the thread in the post above to understand what you need to do. PM if you have questions.
Old 06-14-2011, 01:47 PM
Dankwgn420's Avatar
thanks guys im gonna start finding the parts
Old 06-14-2011, 02:00 PM
fsttyms1's Avatar
you should look for the 09 TL intake mani. Its better.
Old 11-17-2011, 04:07 PM
Dankwgn420's Avatar
does the 09 bolt mani bolt up
Old 11-17-2011, 04:58 PM
Unregistered Member
Karanx7's Avatar
Yea, but you'll have to get a TB adapter from P2R. Also, I recommend you get it done by a shop. I hear a lot of "vac leak from 09 IM" threads, so it would be nice to have it done carefully and hopefully with a warranty.
Old 11-17-2011, 06:31 PM
fsttyms1's Avatar
It sounds like you need to use the gaskets from the adapter and not the oem ones, along with a bit of honda bond to fill a small hole?
Old 01-07-2012, 08:06 PM
BlackIceKola's Avatar
you also need to run another throttle cable to actually open up the butterflies..Its a lot of work and if you are serious about doing it I would look at some junkyards that have 2000 and up TLs to get everything you need.
Old 01-07-2012, 08:07 PM
And dont forget the computer!! lol
Old 01-10-2012, 11:24 PM
R2D
R2D's Avatar
So I have a 03 Tl none type s but I want to install the type s intake mamifold so what other parts would I need to make this work?
TypeS860
09-03-2021 06:42 PM
rcs86
08-02-2016 06:52 PM
hpfiend
09-27-2015 06:59 AM
Quick Reply: 2 stage intake swap onto 99 tl-p
