Zaino Smears?
Zaino Smears?
OK, so I washed the car with Dawn and dried it Saturday afternoon. (This was to be my first application of Zaino products) I then applied a light coat of Z-1 and let it set about a half an hour. I then applied a coat of Z-5 as my first polish coat. (I intended to follow that up with a final coat of Z-2)
I put the Z-5 on at about 3pm a few miles from the Pacific Ocean in So. Cal. I left it on until about 5pm before trying to remove it. Some of it looked hazed white and some of it still felt slightly damp. I started to remove the hazed portion with the 100% cotton USA towels, but found that it sort of smeared around. Since the ocean breeze was now really moving in and the temp was dropping... I just pulled it into the garage and said that I would let it set overnight before trying to remove the rest of it.
Sunday I went out and removed it with the towels. However, I still can't seem to get all of it off without just moving smears around... When I get it in the sun, I can really see smears that just move around with a clean towel. It sure shines and feels nice though. DID I PUT TOO MUCH ON OR SOMETHING? I didn't think I used that thick of coat... What should I do now? The instructions say to use a wet towel to wipe it down or to rewash it with Zaino car wash...
What would happen if I put a second and final coat of Z-2 on it in this current condition? Would everything dryup and be able to be removed together, or am I stuck with having to wash it all over again? And will that really take care of it? Is this stuff that much of a pain to work with? I let it set overnight and used cotton towels... Everything according to the instructions. What went wrong? Are these smears a constant problem? Did I not wait long enough in between the coat of Z-1 and Z-5? Does it need to be in the SUN to really cure? Once you start rubbing it off, are you screwed for life (with the smell of bubblegum) once you start, if you start too soon?
Bottom line... I want at least two coats on my ABP before another road trip next weekend. I don't have all day and all night to work on it. CAN I ADD THE SECOND COAT OF Z-2 OVER THE SLIGHTLY SMEARED YET MOSTLY REMOVED FIRST COAT OF Z-1/Z-5 OR SHOULD I WASH AND DRY IT AGAIN FIRST? And then, How do I know when it is really ready to be removed? Should I park it in the midday sun? Putting polish on my car during my lunch and then waiting till the next day to remove it at lunch sounds ludicrous. I guess I should have invested in some of that curing stuff additive (Z-whatever it is). Is that the ticket? I had already gone back to the well for a second order of gimmicks, before starting this, and didn't feel it necessary since I didn't live in Alaska, But maybe SO. CAL near the Ocean is the next closest thing? I'm NOT flaming Zaino here, but not having the easiest experience with it yet, either
I did the same, too thick, a little goes a long way. You should barely be able to see it on the surface of your car. Make sure the temps and humidity are where they should be.
I got the Zfx, but haven't tried it yet.
I had the same problem with Zanio smearing. After using up my suppy of Z2, I have switched back to my suppy of Meguiar's.
I waxed with Meguiar's this weekend, and I think it put's on a deeper shine than the Zanio.
I typically wax at least once a month. I use the Final Inspection after every wash. Wash at least once a week.
Once my Meguiar's is gone, I may try the P21S line of waxes from autodetail.com.
Originally posted by Ruski
You may have applied Zaino too thickly.
You will probably have to rub a bit to get that Zaino off. However, per everything I've read, it needs to be removed and then cure for 24 hours before the next coat.
Originally posted by daryl.com
too much involved? do you still go to the gas stations that pump your gas for you?
I was just going by the process on their site....I havent done it, but it seems like a whole day process?
The Middle Atlantic sales rep for Meguires is actually a friend of mine and he has taught me alot. I've ended up using their Gold Class wax followed by a mist coat of their Final Inspection if needed. This removes that haze you see sometimes - he said it is just wax residue that is difficult to wipe off the car. The shine is spectacular.
No, you are a dork.
Originally posted by bloo_tls02
No, I make my wife pump my gas:thefinger
Since you sound like the type that likes to take shortcuts in everything you do, you can really get away with only doing Z1 and Z2 an be thrilled with the results.
No, you are a dork.
Maybe i'll print it out and read it over while i'm taking my eveing dump. Not that I'm into taking shortcuts, just havent got time to go thru the whole ordeal. How long does it usually take anyway (the full process)?
No, you are a dork.
I'll have to check it out and maybe do some searches on how different people use it.
Confucious say may you logs be long and filled w/ corn :toothless
Hey...I KNOW this is an old thread but I need help. I went through EVERY towel in Bed Bath and Beyond and Target yesterday and the closest I found was 100% USA made from Brazilian cotton. Should this mean it was held to US standards? It was Wamsutta collection.
EVERYTHING was from Thailand/Pakistan/China.
Anybody? Where else should I try or was that ok? What about bamboo thread towels. Those felt soft!
Team Anthracite President
Old T-shirts work the best.
Michael
This should help!
https://acurazine.com/forums/showthr...=546274&page=2
Michael
This should help!
