View Poll Results: what is the mileage on your TL?
less than 100k
![](https://acurazine.com/forums/images/maestro/polls/bar2-l.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar2.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar2-r.gif)
![](https://acurazine.com/forums/clear.gif)
18
20.69%
between 100k to 150k
![](https://acurazine.com/forums/images/maestro/polls/bar3-l.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar3.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar3-r.gif)
42
48.28%
between 150k to 200k
![](https://acurazine.com/forums/images/maestro/polls/bar4-l.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar4.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar4-r.gif)
22
25.29%
more than 200k
![](https://acurazine.com/forums/images/maestro/polls/bar5-l.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar5.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar5-r.gif)
5.75%
Voters: 87. You may not vote on this poll
your mileage and repairs done to your ride.
2002 TL-S
174k
on the third tranny (2nd to me)
replaced axles
replaced both ballasts
possible exhaust leak![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
a/c harnass/transistor
i think thats it other than regular oil changes/brake pads
174k
replaced axles
see the main thread list, or problems and fixes, for a list of whats failed and mileages.
a little reading on your part~
S E L L
106,600+ miles
- Transmission replaced under warranty
- Front and right side engine mounts at same time as transmission
- Replaced shitty warped OE rotors with Raybestos Advanced Technology rotors and haven't had a problem since. It's been about 20K miles or so.
Other than that, just typical maintenance like oil changes, plugs, tires, and most recently the 105K mile maintenance. No breakdowns or unexpected repairs.
Although at my next oil change I will be replacing the damn oil pan.
The oil drain plug threads were damaged from the previous owner and they finally gave out with the most recent oil change. I wasn't happy with the way the oversized plug went in so it'll be a new pan in about 6000 miles.
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
![Bored](https://acurazine.com/forums/images/smilies/bored.gif)
123 000 Miles
2003 Acura TL-S Build date (NOV 2002)- Covered Under Ext. Warranty!!
3rd Tranny
Replaced Front wheel bearings
Front Motor Mount
AC Compressor Replaced
Blower Motor transistor
-Leaking Flex pipe
So far that's about, it all the repairs aside I'm still VERY satisfied with my ride!!
3rd Tranny
Front Motor Mount
-Leaking Flex pipe
02 WDP type-S Navi
113k Miles
-Transmission replaced under warranty
-Both Side and front motor mounts
-Timing Belt & All other belts
-Tensioner
-Water Pump
-Radiator sprung a leak
-Two radiator hoses were warped under heat and busted
-Rear Endlink snapped in half
-All 4 rotors replaced due to extreme warping
-Spark Plugs
-Busted Struts (soon to be replaced)
-Tensioner
-Water Pump
-Spark Plugs
103,000 miles. '02 TL-S
Replaced front warped rotors ~30k
All motor mounts~75k
Transmission replaced under warranty ~85k
Timing Belt, Tensioner, Water Pump other belts, Spark Plugs 100k
Normal tires, oil change etc.
2003 TL-p
87k miles
new tranny at 81k
2 front motor mounts, side mount, rear mount
new internals/custom headlights.
replaced brakes with EBC all around
replaced worn out suspension with B&G kit
replaced jammed up cd changer with aftermarket
other than that, general maintenance, its been a good car to me.
new tranny at 81k
S E L L
106,600+ miles
The oil drain plug threads were damaged from the previous owner and they finally gave out with the most recent oil change. I wasn't happy with the way the oversized plug went in so it'll be a new pan in about 6000 miles. ![Bored](https://acurazine.com/forums/images/smilies/bored.gif)
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
WINNING
120k now..
replaced original tranny at 90k.
changed timing belt, sparks, rotors, regular alignments.
Next week getting it touched up (some paint on bumper).
the following week power steering fluid, brake fluid, changing the upper control arms and ball joints for the 3rd time..and coolant flush.
2000 Acura TL
2000 TL
205,800k
Original Tranny, did timing belts/pump and tune-up about 2k miles ago.
Replace side engine mount while back, needing front mount replace but strap on cash.
205,800k
I need 2 more gears
209k
replaced tranny at 143k
replaced front and side motor mounts
replaced upper control arms & ball joints
Replaced lower ball joints
replaced all 4 strut mounts
replaced evap canister and vent shut valve
replaced ignition switch
replaced tie rod ends
replaced tranny mounts
plenty of other stuff but I'd consider those mods, which don't really count.
~111k
trans replaced at 18k
owned since 93k
since then:
replaced rear view mirror
brake light switch
ignition switch (free under recall)
transmission @ 98k (i got lucky and received 100% goodwill
engine mounts w/trans
one ignition coil
rotors/pads
105k service
other than that, just oil/brake fluid changes, cabin filter changes, etc
probably should start thinking about trans fluid change
now hopefully it just works...
owned since 93k
since then:
brake light switch
one ignition coil
rotors/pads
105k service
2003 TL-p
need to add
87k miles
new tranny at 81k
new tranny at 81k
did upper ball joints, replaced uppers with new control arm last week.
Should I feel good about this problem history ?
99 TL - 84K miles (I've owned this car since new)
Previous Issues
Right rear caliper
All rotors
Key fob
Rear brake lines (both)
Wiper arm link
Ignition switch
All rims refinished (due to extreme oxidation)
Front and side engine mounts
EGR Valve
Pending Issues
Clock missing segments
AC not working
Front rotor(s) warped
Pending Maintenance
Plugs
Timing belt et al
Cabin filter
Brake pads (constantly)
Previous Issues
Right rear caliper
All rotors
Key fob
Wiper arm link
Ignition switch
EGR Valve
Pending Issues
AC not working
Pending Maintenance
Plugs
Timing belt et al
Cabin filter
since i had the car Feburary 2009 (80k)
windshield wipers
regular oil changes
front brakes replaced--midas (screwed)![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
front brakes replaced 2nd time---midas (screwed)![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
4 front new tires
balancing and rotating tires
wheel alignment
regular transmission fluid change
cabin air filter
spark plug replacement
clean egr port and valve (annoying process and i did it in the winter
front and side engine mount
brake fluid flush
front and rear rotors & brake pads (did myself)![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
passenger side caliper bracket replacement
timing belt & water pump & coolant flush![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
5000k hids
keyfob
new hood struts or hydraulic holders
now i have to replace my rear driver side window regulator and get 4 new tires and replace my cracked front-shield and replace the 2 tranny mounts and rear mount. i spent a good sum on the car so far. not bad for a 99 though
(111k)
windshield wipers
regular oil changes
4 front new tires
wheel alignment
cabin air filter
brake fluid flush
5000k hids
keyfob
S E L L
Previous Issues
Right rear caliper
All rotors
Key fob
Wiper arm link
Ignition switch
EGR Valve
Pending Issues
AC not working
Pending Maintenance
Plugs
Timing belt et al
Cabin filter
Previous Issues
Right rear caliper
All rotors
Key fob
Wiper arm link
Ignition switch
EGR Valve
Pending Issues
AC not working
Pending Maintenance
Plugs
Timing belt et al
Cabin filter
Hi Gfaze :
The calipers are original with exception of the one replaced which is an OE reman unit. I remove all the calipers, lubricate and free up the pads once per year. It doesn't seem to help much but I can now do a brake job on a TL in my sleep !
Part of the my problem is I use the car in an urban setting with low mileage but lots of starts and stops. That said, I have always felt that our cars have undersized brakes and that Honda used an accountant to decide on their brake systems.
There has been significant discussion on this board regarding which brake parts are best for our cars. From what I can determine, most of the comments and experiences seem to eventually return back to OE Honda parts.
195,300 miles
3rd transmission (orig, 1st replacement, 2nd at 85K intervals)
Engine and transmission mounts
HVAC mixer motor
Front sway mounts
Front ball joints
Drivers seatback heating element (a DIY job)
B-Pillar re-vinyling
Front rotors due to warping, backs just because.
Replaced brake reservoir cap (contains float level)
SRS computer
Impact sensor
Total parts/service costs since 2000: $7946.17 (includes oil changes, tires, brakes, etc - everything except gas)
HVAC mixer motor
Front sway mounts
Front ball joints
SRS computer
Impact sensor
MechEng
104800 miles
motor mounts
timing belt
water pump
left front fender splash shield (came off while driving, thank god no one was behind me)
b-pillar repair
front lower ball joints
exhaust leak
motor mounts
timing belt
water pump
b-pillar repair
exhaust leak
I spoke too soon when I said hopefully it just works. Ignition switch going bad in a hurry.
~111k
owned since 93k
since then:
brake light switch
one ignition coil
rotors/pads
105k service
owned since 93k
since then:
brake light switch
one ignition coil
rotors/pads
105k service
I'm stock and hating it.
220xxx
1 Tranny(failed at 118xxx and the dealer covered parts)
1 Timing Belt and Water Pump
Once Front and rear rotors
All motor mounts Once
1 Battery
Spark plugs Twice
SRS module i think(dealer handled that)
Valve cover gasket.
thats it other than the regular stuff like oil.. seafoam.. stuff like that
1 Battery
Spark plugs Twice
Valve cover gasket.
2000 acura tl FPR
178kxxx
bearing in a/c compressor was going bad and a/c didn't work so replaced that
new pads rotora rotors
1 battery
1 set spark plugs
1 new IACV
then to the goodies, (everything here has less than a mile on it still waiting on tune)
j32a2 with 50k
cleaned intake manifold/throttlebody/EGR port
new timing belt/waterpump
new OEM quality flywheel and clutch (i didn't know i was going turbo
new rear main seal
S2k injectors
2003 CL-S6 transmission with 72k
pspec RSX short shifter
Garrett T3/TO4e .57 trim turbo
tial wastegate at 5.8psi
XS headers
XS intercooler
Haltech Platinum Sport 2000 Standalone (being tuned)
1 battery
1 set spark plugs
1 new IACV
j32a2 with 50k
new rear main seal
S2k injectors
XS headers
XS intercooler
125,000 miles, got it as 55,000 miles and since then:
2 transmission replacements
2 tensioner pulleys
broken drivers side seat heater
SRS light that wont go away
2 Sets of CV joints
Motor Mounts
Rear Ball Joints
Strut Mounts
HVAC blower motor and wiring
EDIT: 2 ballasts, 2 bulbs, and 2 ignitors
2 batteries
and im sure im forgetting something.
this car has been a piece of shit.
2 tensioner pulleys
2 Sets of CV joints
Motor Mounts
Rear Ball Joints
Strut Mounts
2 batteries
had it from new, now have 143,000
-3rd tranny under warrenty (last one at 100,000), dealer replaced after checking - I had no symptoms
-seat heater at 99,000 under warrenty (extrended)
-brakes and rotors (normal wear and tear)
-broken fog light lenses, replaced with Lexan
-clock light (PIA to replace)
-timing belt and tensioner at 120,000
-new plugs NGK Iridium
Real reliable for me..hope I did not jinx myself
just rolled 95k this morning
original tranny
new brakes /rotors next week sloted and crossdrilled $225
2 new fogs and bumper cover $400 and yet to be put on
timing belt water pump and plugs today
need to find out why my odo keeps shorting out light keeps going out
original tranny
2000 TL, 91K miles, all by me.
Original tranny, but now noticing the dreaded shudder in shifts from 2nd to 3rd. At 40k dealer had inspected it under warranty and installed the "lube pipe".
Here are my repairs, mileage and the Chantilly VA dealer price tag (OUCH!):
front lower ball joints, 60K, $425.
rear brakes, 60K, $325.
battery, 60K, $145.
front brakes, 65K, $392.
timing belt and water pump, 70k, $849.
diagnose a CEL, replaced steering switch and MAP sensor, 75K, $650.
replaced brake fluid cap/sensor, 85K, $42.
battery, 60K, $145.
Received 1,080 Likes
170K
2 transmissions
2 sets of motor mounts (2nd set going in this week)
2 batteries
2 end link brackets
end links
catalytic converter (going in this week) - no CEL but a piece of the catalyst is rattling around inside
1 coil pack
HID bulbs
2 transmissions
2 batteries
2 end link brackets
end links
1 coil pack
HID bulbs
123.xxx
2002 tl-p
had it since 94.xxx
since then
tranny changed at 93.xxx (previous owner replaced it )
possible engine change also (it was in an add when i bought the car lol
EVAP - canister and sensors changes (engine light is still on)
rotors and break pads
tires
timing belt, water pump , etc
reg oil change
front engine mount
side engine mount changed twice
front bumper + grill
so far car runs great , cant complain reliable to me
2002 tl-p
had it since 94.xxx
since then
tires
reg oil change
front engine mount
