You never go full retard- the Timing advance thread (calling all gurus)
I am about done with my NA mods and the only thing left is to get the type-s ECU.
While i am looking at the instructions on how to re-wire my chassis i stumbled across our frame to power torque down request connector.
When our car needs the timing retarded-for traction purposes, it sends a 5V signal.
When their is no need for timing retard it sends a constant 2.5V signal.
If you ground it, the cable throws a code.
There is also the Inhibition to frame cable. This prevents all timing retard during non-optimal coolant temperatures.
(below 32 degrees F) by sending a 5V signal. 2.5 allows retard.
pic below
Uploaded with ImageShack.us
This is for the TL's with TCS. if anyone can provide the Type-s diagram please do.
pic below
If we provide a constant 2.5V signal to the inhibition sensor will this mean it will run at full advance? please correct me if im wrong.
Couldnt we also install a potentiometer for tuning purposes?
im asking this because ive read that none of the tuning piggybacks can ADVANCE timing
great scotts marty..!
We can use many thing to retard, we cant advance. If what i think phe is asking actually works it would allow us to full advance the timing then use a controller to retard it some to tune it best while still being able to "advance" it with out actually advancing it?
B A N N E D
then the permission signal is just to tell the tcs module that it will not drop down power
so if you do not hook the tcs/abs up to the ecu, then yes you need some type of resistor or pot, to be able to always put 2.5v on it, so that it will always try to fully advance the timing (and anyways the ecu tries to fully advance the timing on it's own, that's why it has a knock sensor, advance it till it sees the knock sensor come on)
but on a other wise stock car it is already fully advanced (it is basically for the tcs/abs to be able to tell the ecu to drop power)
B A N N E D
quite simple in theory, but on the expensive side to implement though (not so much on the crank though, more on the cams more so)
i know :tongue, that is the reason why we need some adjustable cams and such , have to "mechanically" advance the timing (by advancing the pickups and such), then we can use the crappy piggybacks (i wish there was a standalone option that was reasonably priced ) to just retard it from there, and know that when it says it is 30 degrees advanced in reality it is really 40 degrees (or however much the pickups where advanced)
B A N N E D
but i would not worry too much about getting the timing advanced though, as i would be about getting the AFR correct, cause the computer will just advance the timing till it sees the knock sensor detect knock, then it will back off, or just stop advancing it (and being able to manually advance it is even less important once the ecu is able to fully relearn anyways)
till you start pushing into the 100's of octane for the fuel rating though, then that is another story though
B A N N E D
but the motor itself was not built to take advantage of 93 though, (aka compression wise) only 91, so you won't get more power from the higher octane fuel (i want it, so we can see what the computer will max the timing out at though; aka it's limit), and anyways all street gas has basically the same BTU output (including 85 here) as each other, so it will basically make the exact same power
then as far as octane is concerned, it is a measurement of basically how long it takes to burn/resistant to being ignited
higher octane fuel actually takes longer to actually burn then lower octane fuel (the reason needed for more advance on higher octane), so it is able to withstand the extra heat generated by the higher compression ratios, with out igniting prematurely (aka the spark plug needs to ignite it)
so i bet if those people running that 94, bump up the compression ratio (including just shaving the head for head gaskets or something), that they would see an increase of power from running that higher octane (only if the compression ratio now excedded what the 91 could support though)
also basically boost=higher compression
B A N N E D
but then again for the computer advancing the timing
higher combustion pressures from increased compressions, also cause the air fuel mixture to burn faster, so the factory ecu may still be able to advance the timing as needed on a fully built motor running 110 octane or so, since the faster burning mixture (higher compression) is offset by the slower burning fuel (octane)
We need this to go further. It would solve all of our problems!
http://www.j32a.com/showthread.php?t=442
B A N N E D
Actually the last post was 5/11/10. Once you register you get to see all the pages
mada51589
05-03-2022 08:54 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
