Wood Steering Wheel
Wood Steering Wheel
After doing a search and reading around, I'm still somewhat confused about the wood steering wheel that can be transplanted into my '00 TL. The instructions i found by teh way are awesome.
So if I were looking for the wheel, what is the easiest way to acquire it, which wheel should I use (Accord, MDX, TLS, CLS?), and what should I expect to pay.
Also, how did people get past the special bolt that most airbags have on them? I know they put a bolt on there which has a hard-to-find wrench in order to prevent airbag thefts. Any hints? thanks!
Just don't buy one thats off a mdx, they won't fit. The mdx's is not as shallow as the one for the TL. I installed on from the 98-2002 accord and it fits perfect. And you really don't need any special tools, once you get the airbag and screws off...you just give it a pull and the steering wheels comes off. Make sure you disconnect your negative battery cable. good luck
thanks for the advice. Will try it when i get back. I didnt know accords came with a wood wheel option! why wasnt that an option for TLs?? (all i remembre was a shift knob avail. in wood).
rockyboy
08-04-2024 10:35 AM
EvilVirus
12-10-2015 07:38 PM
