The Wobble
Old Nov 30, 2017 | 07:19 PM
darkdeuce's Avatar
The Wobble
It sounds like a new dance craze, but its what happens when I'm driving...even at speed.
I noticed today that it happens especially while turning right. Only while accelerating or on the freeway.
Braking IS NOT affected.
After scouring posts, I am figuring that it's gotra be either the CV Axles or the motor mounts.
A mechanic friend says that he thinks it's the tranny dying.
Bushings are worn and will replace.
Whats your take?
pushing 225k.. both are probably original.
Old Dec 18, 2017 | 07:31 PM
Type3.2's Avatar
5th Gear
Sounds like a wheel bearing going out.
Old Dec 23, 2017 | 05:54 PM
Chojun's Avatar
I have a bad wheel bearing. It makes a pretty noticeable grating/grinding roar, especially on the freeway. But I don't have any wobble.
More than likely it's sway bar end links. If not then check ball joints, tie rod ends, steering rack.
Old Dec 24, 2017 | 05:55 PM
bbsitum's Avatar
Can be bump int tire. Check it first.
