Wiring through a grommet
/etc/car
Been trying to get a wire through the grommet above the e-brake for the last 2 hours. My hands are cut to pieces (blood all over my floor mat), scraped, dirty, etc...and no wire to the engine.
Is there some secret to doing this? I've poked a countless number of holes through it...big screwdrivers, little screwdrivers...each time checking to see if it came through. It did.
The wire won't go through...and it won't go through if I tape the wire to a screwdriver and shove it through...
How did you guys get past it?
hmmm, maybe you can bend the wire over a flat head, giving a couple extra feet of slack, so you're actually pushing 1 bent piece of wire thru (twice the thickness), after its thru, pull out the slack ?!?!?!?
Know what I mean Vern?
RU kiddin, its a snap!! U said you got the screwdriver thru right?? well, put wire tightly over the tip with both ends back in your hand, slip tip thru, Go into engine compartment and pull wire out... pretty easy
/etc/car
It won't go through...the screwdriver will go through by itself..but not with the wire taped onto it.
I think I damaged the grommet, too...it's not flush against the metal on the engine side anymore.
..and I thought this would be easy, since removing the rear seat was a snap...
/etc/car
18 gauge powering a 400 watt amp? hehe...
BTW, it sparked, I smelled burning electronics, and the instrument panel backlights don't work.
Perfect. What kind of story can I make up to get Acura to fix it?
Man, this is so easy, here's all you have to do
1> Get a long philips screwdriver and push it thru the grommet to the other side. Once it's thru, wiggle it a bit to loosen up the hole
2> get a wire hanger, straighten it out, stick thru the firewall so both ends can be seen (one in bay, one inside).
3> duct-tape the power wire to the end of the hanger that is inside the car. TAPE IT TIGHT AS HELL AND TAPE IT UP THE HANGER.... NOT JUST WHERE THE WIRE IS.
4> Go to the engine bay and pull it thru.
As far as your bloody hands, sparks and electrical burning scents, UNPLUG YOUR BATTERY !!!
/etc/car
Ok..I found the fuse...it was the one under the hood called "small lights". What the hell kind of name is "small lights"? Wouldn't it logically be called "instrument panel", which is what the one next to the steering wheel is called? Must be a bad translation
Anyhoo, the stock sub doesn't work now either...and all I did was use wire tappers on the 2 wires inside the brown wire...I even reconnected the shielding because I had to cut it to get the wires apart...
...and you guys thought I was kidding when I mentioned I couldn't change the headlight in my old '88 Legend :yack:
I think what you need to do is to take a break right now to regain your composure. You're probably too frazzled with all the cuts and problems that you're going to make it worse if you go on.
I have a limit set to detect fatigue: if I make three stupid mistakes in a short period of time, I will drop whatever it is I'm doing, lean back and take a 15-minute break.
/etc/car
Is there a secret as to reaching the grommet?
I can't see it from the inside since it's so far up...I can barely reach it from the inside.
I can kind of see it from the engine side...and kind of reach it.
Every time I poke through from the cabin side, it doesn't go through far enough to get pliars down to grab it...everytime it pokes through from the engine side, I can't reach up in there and grab it. I'm praised for having large manly hands by the wifey...but it certainly isn't for car work
Acura604
20
08-05-2017 12:55 AM
SUPRMN84
10-07-2015 09:46 PM
