Wiring ESM Help!
Wiring ESM Help!
ESM Black -> PCM C7 (Grn/Wht)
ESM Red -> PCM C19 (Yel/Red)
ESM Green -> PCM C17 (Grn/Red)
ESM Blue -> map sensor (Grn/Red)
I’m confused… according to the diagram there’s only 3 wires from the map sensor. Wiring the black, red and green from the ESM to the PCM connections I’m fine with but it’s the blue wire from the ESM to the map sensor I’m confused about… where do I spice into? Do I splice into the same wire ESM green is spliced to or is that a whole different Grn/Red wire?
http://www.in.honda.com/Rjanisis/pub...903023003A.pdf
Also my ESM is used and so i have only the 4 colored wires (1) green (1)blue (1) red and (1)black
is it neccessary to to have the (1) green (1)blue (2) reds and (2)blacks as shown in the CT installation manual?
Can anyone confirm that the ESM is to be in between these wires as shown below?
PCM C17 (Grn/Red) <- Green ESM Blue -> Map Sensor (Grn/Red)
PCM C7 (Grn/Wht) <- Black ESM Black -> Map Sensor (Grn/Wht)
PCM C19 (Yel/Red) <-Red ESM Red -> Map Sensor (Yel/Red)
Acura604
20
08-05-2017 12:55 AM
SUPRMN84
10-07-2015 09:46 PM
