wipers will not shut off
2003 tl wipers work perfectly except when turned on they will not shut off until the power is removed. By this I mean that if turned on you must turn the wipers off and then turn the ignition off to stop them. I can also stop them if I turn the wipers off and pull the fuse for the wipers (drivers side fuse box). Unfortunately no one else on this forum seems to have had this problem.
thewipers remain off when I replace the fuse. In simple terms, something is not telling my wipers (or wiper motor) to shut off when I turn them off.
ck the switch at steering wheel
Puma Jim
20
10-20-2016 11:59 AM
