Windshield Wipers
Windshield Wipers
Anyone have an opinion on what are good windshield wipers? Got to get new one's and just wondering if there are any to stay away from?
ChairmanMaoSaysRTFM
i'll tell ya, i've bought bosch, anco(sp?), and a few different ones, and the bosch were the nicest, BUT every single wiper i've had on the tl i find that i have to wipe the rubber blades down once or twice a week with windex. otherwise they build up too much gunk and i find them to be pretty useless in the rain. i really have never had this much of a problem before. i am curious to see what the others recommend.
SSTS
SSTS
Just by the replacements refills from dealer parts counter. The refills are less than 6 dollars. The problem is true about the build up though. The build up on mine is not that much though. Try Rain-X on the windsheild and see if that helps. Good Luck!
I like the Bosch or PIAA wipers and you can get refills for them too. I also try not too put toom much wax on the hood, I found that the excess wax tends to splash onto the windshield when mixed with the rain.
I also flip the inserts of the wipers over so that it does not alway leaning to the same side. Is a little trick that I picked up when I was the maintenance director at Avis car rental. It gets expensive when you need to get wiper replacements for 5 to 8 thousand cars. You would be amazed how much better it gets when you flip the inserts. It basically double the life of the inserts.
I usually flip them the same time when I get an oil change and I am able to get about one year out of each inserts then replace them with refills.
i use the PIAA brand, there silicone, but there expensive! the best wiper i have ever had! comes with a silicone packet to prep the windshield for great break in , i have them on since december and i like them alot. my ACURA OEM wipers would chatter and skip and made the wiper arm make a grinding noise. but when i switched to the PIAA wiper and blade arm, its now quiet and smooth. a real big difference for about $27 for driver side and $24 for passanger side on the internet somewhere.
Try flipping your inserts for every oil changes, because when the wipers comes to rest at the bottom of the winshield it puts pressure on the blade. No matter how good or expensive and Silicone or not, over time the blade will start to lean to one side. If you lift your wiper off the windshield and look down the side of the blade and you will know what I mean.
It would extend the life of the blade then the $27/$24 price tag would not seem as bad.
Head Wanker
SSTS
SSTS
I got the PIAA ones because the stock blades were so much crap. They work much better than stock but I still have to clean them everytime I wash my car or else it does leave a weird residue when you wipe. Note that on the instructions for the PIAA it says don't wipe your blades or else it will deform the silicone or something. I ignore it since not doing so makes the wipers useless.
Athena says 'hi'
I actually got wipers yesterday -- I'm trying two different brands -- one was the Bosch Premium blades and the other is a Anco Premium. I'm gonna see which one lasts longer. The main thing that was important was the steel blade instead of plastic..
http://www.acura-tl.com/forums/editp...post&p=913309#
Kollage is funn!
1 Post
i always keep a coating of RAIN X on my windsheild at all times...it really helps. I find that my stock wipers are pretty good...on my other car i have BOSCH MICRO EDGE EXCELL blades, and it must be from the blades cuz the RAIN X doesn't last more than 1 rainfall....it REALLY sucks....so i'm definitely going to buy ACURA replacements. only 1 question though, you think the ACURA parts dept replacement will be the same or really close to what CAME on our cars??...thanks. -shawn
woooo!!
Yeah, I know it's an old thread but I had to give another vote to PIAA silicon wipers. Just got them installed and took my TL out for a little drive in the rain (pretty heavy). The results? I did not even have to use the wipers once the whole way driving around a few blocks. Why? Thanks to the silicon treatment the water droplets rolls right off to the top of the car when you are at a decent speed (say 30+ mph).
Using the wiper blades cleans up the vision even more... it's amazing... you just gotta see it for yourself. I just hope the silicon layer doesn't die on me too quickly... though I have an extra packet of treatment saved for later.
Well worth the 40 bucks (the whole set shipped) spent!
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
