Windows top noise when closed
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
Have anyone notice the friction noise of the power window on top of the TL-S when closed?
How can I get rid of it? Can I put Armor All on the side of the windows ?
I had the same problem with my 98 CL, sometimes you would actually hear a loud screach.
Clean the edge of the window all around with bug & tar remover and clean the rubber with a rubber cleaner like armorall cleaner then treat it with a protectant. It worked but you will have to continue to do it every so often.
I would suggest you clean the window seals again, and apply some spray can silicone lubricant to the window seals. I've used it with good results for years. You should re-apply it every 3 months or so. Also works great on door and trunk seals.
ahsm
09-09-2015 08:35 AM
