Will they Rub??
Your very close, I heard of even 19x8 w/ +45 offset not rubbing. Just a little trim of the back tab thing! so it looks like 19x7.5 w/ +44 should barely make it (again with a little trim). I would say 19x7.5 w/ +48 and 19x8 w/ +50 if you don't want to trim anything!
P.S. what rim are you looking at???
Re: Will they Rub??
Originally posted by FLAcuraTLS
Hey guys, can anyone tell me if 19x7.5 +44 offset will rub on my TLS..I have H&R sport springs.
Thanks for the tip dragon, but offset goes by rim width, not diameter.
BTW H&R springs would not make a different when it comes to rubbing. As might as well any aftermarket spring/coilover. Since up/down motion of the wheel is control by arms. Having a lower spring would not change the path/angle of the wheel as it goes up and down. This will always be true unless you get a camber kit, since our rear suspension are not camber adjustable.
I have 19x8's w/ +40mm offset, Comptech springs, and no rubbing. Just need to trim a little plastic in the rear fenderwells. You may not even need to do that. And I didn't need a camber kit for proper alignment either, just a good shop. I recommend Weber Alignment in West Palm Beach, no one's better.
http://www.acura-tl.com/forum/showth...threadid=24311
There are pictures at:
http://community.webshots.com/album/23017103cSJNbrqiRC
check out the ones marked "fender trim" for details.
My question: Do I need to take the tire off if I plan on doing it with the dremmel or should I have enough room to shave it down with my rear wheels in place?
Originally posted by Tleast
Thanks for the pics. My new rims and dubs are rubbing in the back, and I am going to start by trimming down the bumper tabs.
07-16-2017 08:33 AM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 10:38 AM
