Will installing an intake void the warranty
Guest
Posts: n/a
If I install my aem intake will it void the warranty or if i purchase the intake and have the factory install it the intake for me will it void the warranty.....
I have the same question only with the coil overs also...will putting coilovers void the warranty
S/C'd Accord Coming Soon!
An intake will not void your warranty and neither will coil overs.
Anyone who tells you different is being straight up with you. Check out www.sema.org They represent aftermarket part manufacturers.
Things like new cams, high compression pistons, and stuff like that will void your warranty on the internal parts of your engine.
Warranty is based on cause and affect. If an aftermarket part did not CAUSE the problem, then it does not AFFECT the warranty.
By law the dealership has to prove that the part you added caused the other part(s) to break.
Brian =B-)
2000 Accord LX V6 Sedan White - 3,310 lbs w/ driver - 170HP & 160ft/lbs
- Koni Yellows & Eibach Pro-Kit (1.5" drop)
- Red AEM Short RAM Intake (8-10hp & 5-6 ft/lbs gain on a DynoJet)
- Red AEM Tru Power Pulleys (10hp @ 5,600rpms & 11ft/lbs @ 4,600rpms gain on a DynoJet)
- 15.45 @ 88.8mph (Track) [with AEM intake/pulleys] 0-60mph 7.2 sec (G-Tech) [with intake/pulleys]
By law the dealership has to prove that the part you added caused the other part(s) to break.------------------
Brian =B-)
So putting on coilovers or springs won't void the warranty on your shocks???? Cuz they put more wear on your shocks. So does that mean that if My shocks go out because of my springs they will change the shocks under warranty???
Just try to use common sense. If you put 120 octane gas in your car, and all your spark plugs foul up, should Honda cover that under warranty? NO, because you used a higher octane gas than you should have. No if your alternator goes out after using 120 octane gas, the alternator would still be covered under warranty.
cycdaniel
Dec 17, 2019 10:58 AM
Abe_Froman
Sep 16, 2015 01:27 PM
asahrts
Sep 4, 2015 05:55 PM
