will I rub?
will I rub?
I have some Konig Absolute's 18x7.5 rims with Nitto 555 225/40/18 tires. The offset on the rims is +45. I want to get the H&R sport springs, does anyone know for sure if I will rub? I also have the OEM kit. Anyone running the same that doesn't experience rubbing?
You will be fine. I have the Konig Toxxins with comptech springs. I had the 225/40/18, and now I have the 225/35/18. Reason I went with the 35, made it look more aggressive. Either way, you will be just fine.
the reason I ask, is cause i heard that if it does rub, some people have sanded down the tab or something in the rear.....not sure what they talking about, cause I look and I don't see a tab. LOL
fortunate: http://www.tirerack.com/tires/tiretech/general/size.htm ... great info there.
In a nutshell: 225 is the width of the tire in MM. 45 is the ratio of sidewall height to width. The lower the number the lower profile the tire. 18 is the diameter of the tire.
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
