will Acura Cl strut Bar fit 1999 Tl
u mean the stock cl-s sturt bar? the tl already comes with a strut bar and im pretty sure they are both the same. if you are talknig about aftermarket, then yes they will fit the TL.
yea an aftermaket chrome Neuspeed strut. Do you know how much they are new. I am about to buy a used one, does it make a difference in stiffness?? thanks
Having Fun?
With stock sways the upper-strut tie-bar will not be noticable. Combined with a good set of sways the upper-strut tie-bar will tighten up the steering *a little*
In theory you should benefit most from a tie bar during hard cornering as it is designed to optimize the wheel-to-road ratio
So for daily driving on stock sways, I would say save up for sways first
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Thanks my next move is sways so I will get the bar for like $75 and then order my sways. Are the suspension Tech good sways or should I go with comptech
acurajj
02-14-2016 02:28 PM
