Will Accord camber kit fit?
I wanted to know if the camber kit from the 98 - up Accord V6's will fit the 03 TLS's. Also, how do you read the specs of a camber kit? For instance, I have a -1.6 degree camber in the rear, what would I need?
Some of them will be fit.Because the 90-02 accord,tl ,cl are the same base and suspension.I am using the SPC camber kit.The kit specs is -2 to +4.Before I use the kit.I have the -1.9 degree in rear wheel camber.Now is ok.Because if you have the neg camber (/ \)more than -1 ,it will make the tire inside wear.
What is your kit name?Comptech & eibach camber kit are made from SPC,so they are the same things.And you can check the Ingalls camber kit.But I am not sure it have the kit for the 99-03TL right now.
So that mean it isn't enough and more money.The SPC(67090) is cheaper than that.And the range (-2 to +4) is enough for your TL.That kit is a control arm replace your oem.And it can give you drop your car up to 3"
cycdaniel
12-17-2019 10:58 AM
InFaMouSLink
10-27-2015 06:51 PM
nuldabz
09-03-2015 05:49 PM
