Will 6.5 Alpine TypeS speakers fit?
Wondering if 6.5 Alpine TypeS speakers will fit in the front doors? Any thoughts?
Can I do 6.5's all around or do I have to stick with 5.25s?
Boomer SOONER
there is an audio/video section under the off topic area - search around and you will find out all the info you need.
but to answer your question - you can put 6.5 inch speakers in all 4 door, but you will have to enlarge the original hole some to help it fit (stock speakers are 6 inch). Your only limitation is from the lack of available depth to work with - but that information is all over the audio/video section
I need 2 more gears
I believe alpine type s speakers have a pretty deep mounting depth, something like 2 5/8"-2 7/8" which is pretty deep. Our stock speakers cuttouts are not deep. You will need to use spacers and they still may be too deep. I would get 6.5" with neodymium magnets, kenwood excelon speakers have neodymium magnet. I put those in my wife's corrolla, no spacers needed, they are amped and they sound amazing, after 2yrs of abuse they are holding up great. Much better then the Infinity Kappa's I put in before. those blew after a few months, being amped by same amp 50watts rms.
Boomer SOONER
Boomer SOONER
focals are awesome speakers too, but they are pretty expensive right?
For a less expensive alternative, the Kenwoods were/are very good
'99 Acura 3.2TL
you guys might want to take a look at Hertz speakers (italian). My buddy just started to sell them and he let me hear them... WOW. I was really impressed by the sound quality. Even their bottom line is pretty good (for the price you pay). They're kinda like Focal, but louder (while still keeping the same, great sound quality)
one of my soundstream front speaker is messed up due to lack of clearance (the speaker cracked cuz it was hitting the door panel, it was fixed afterwards but it cracked again...) so i might try a pair of mid-class Hertz speakers in the front.
99 SSM Tl
I had 6.5 alpine 2 way before.. blowed 1 .. if you whant them to fit you will need a spacer unless that you windows will not open with the spacer you will need to cut the border of plastic between the door and the door panel .... i have kicker ks 6.2 now and they fit just right.. and are more powerfull ..
I need 2 more gears
I remember buying a pair of alpine 6.5" type s speakers before and trying install them in my wifes corrolla, they didn't fit but I did connect them to hear them and they sounded great, better than Infinity Kappa's, but not quite as good as the Kenwood Excelon's. Now if I were you I would buy Eclipse point source 6.5's, they don't have the power ratings of the alpine type s or infinity kappa's, they are 100watts, 50rms, but they can handle more than that easily. Eclipse point source speakers absolutely are the best value you can find, they blow away even some MB Quartz coaxials. you can find on ebay for about 100 + shipping per pair. Check 'em out.
I need 2 more gears
I remember buying a pair of alpine 6.5" type s speakers before and trying install them in my wifes corrolla, they didn't fit but I did connect them to hear them and they sounded great, better than Infinity Kappa's, but not quite as good as the Kenwood Excelon's. Now if I were you I would buy Eclipse point source 6.5's, they don't have the power ratings of the alpine type s or infinity kappa's, they are 100watts, 50rms, but they can handle more than that easily. Eclipse point source speakers absolutely are the best value you can find, they blow away even some high end MB Quartz coaxials. you can find on ebay for about 100 + shipping per pair. Check 'em out.
Originally Posted by MrAlex
aftermarket headunit with amp for front vacal and rear stock directly to headunit..
OU sig, did you purchase your focal speakers online, or from a local source? No one carries them around here, and I'm always leary on purchasing speakers I haven't listened to.
Boomer SOONER
Originally Posted by jayhawk815
^^^^Best setup, if you are on a budget.
http://www.cartoys.com/default.cfm//.../orderdir/Desc
focals are extremely expensive, damn OU SIG I knew they were top notch, but expensive is an understatement. Check out their website.
sockr1
10-01-2015 01:31 AM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
