Why not drive at low fuel levels??
I have read in a couple of threads that it is recommended not to drive the vehicle at low fuel levels. Now I have couple of questions based on that:
1) How does one define low fuel level? (is it when the low fuel indicator light comes on)
2) What are the negative effects of driving at low fuel levels?
Thank you in advance.
Riding around all the time on less than 1/4 tank is bad for your fuel pump, and for condensation.
The fuel pump sits in your gas, and uses it to cool itself, so less fuel = less cooling, and more wear and tear on your pump.
An empty tank is more prone to water condensation, than a full one, so if you just want to put a little bit of gas in your tank at a time; suck it up once, fill it up, and then top of every now and then from there.
Condensation is made of water
Water is not combustible
Fuel IS!
Fuel IS!
I'm Down Right Fierce!
Originally Posted by toofanmasti
Mr. Hyde,
Would the condensation in the fuel tank affect the performance (mileage, engine maintenance, ....) of the car?
It's in essence the same thing as putting water in your tank. Allbeit, it's not a ton of water, but still; would you put in 1/4 cup of water into your tank everytime you filled up? How bout an 1/8 of a cup?
Water in the tank is just a bad idea. And as Mr. Hyde explained, running your car on low fuel increases the chances of condensation: i.e. water in your tank.
Just fill up every 200-220 miles and you should be fine. You'd just have to visit the gas station more often, but would spend the same amount of money.
Fill up every 200 miles yikes
Maybe if there were a storm watch and needed full tank all the time!
Drive it to a point just before fuel light and fill up
I also have a dollar per amount of fuel remaining thing in mind- so I know it needs 40 bucks- stop at the station
Originally Posted by bangumandoo
dam how much do you pay per gallon? $40 is a lot for a fill up
A friend of mine told me when I got my first car to always wait till it was almost empty to fill up, something about getting tiny specs of dirt from the gas pump in your tank...I always thought that just seemed stupid, but have always followed her advice. I guess it's time to change my ways. A failed fuel pump doesn't sound like any sorta fun.
Todays gas price is 3.05 per gal for 91 octane
So $45 is what I normally spend- thats 15 gallons
because I fill up at fuel light or before
Air Vice Marshal
The normal problem with condensation in a fuel tank is rust resulting from storing a vehicle. The tank walls are uncovered and condensation can form and sit there. That isn't a problem unless the vehicle sits for an extended period. Filling it every week or so and sloshing around while driving keeps the walls relatively protected. If you're not going to drive it for a while, even a few weeks, fill the tank. Otherwise, just drive it until you need fuel.
As for the pump, yes many pumps are submerged, but the primary reason is because fuel injection systems operate at high pressure, which requires the pump to "push". Putting them in the tank eliminates the suction side of the pump.
Just drive it 'til the light comes on.
Kind of off topic, but how many miles do you guys normally have before you need to fill up on a full tank? I think I get ~ 220 or so, and that's running on a near to empty tank. But I usually ride locally. Is this pretty low?
Originally Posted by fsttyms1
Honestly where do you think the fuel pick up for the pump is?? Its in the bottom of the tank. It doesnt matter if its half full, full or empty, its still drawing in the fuel from the same spot. Plus there is a sock filter on the inlet to trap stuff before it goes into the pump.
2Poor 2Furious
Just fill up when you see cheap gas for whatever brand you want. Saves ya money, and you're usually not empty when you find the cheap gas driving around randomly. Just gotta get in the habit of not being lazy about filling up when you're not empty.
Without a garage
yeah thats about normal for a TL-S. i average 17mpg all town miles. and it's bad town driving with about 25 damn stop lights to and from work.
I need 2 more gears
Originally Posted by tjmedford
270,000 miles and I push it into the gas station. No idea what you are talking about.
You have 270k on your TL? I think that's the most on this site.
someone said something abut using shell v-power in another thread, it's cleaner and burns better from what i understand. i wonder if after using it for a fewtanks if your fuel mileage might get slightly better with it as well due to that...
Originally Posted by Pure Adrenaline
Your first mistake.
Originally Posted by BraveDemon
I'm not Mr. Hyde, but to answer your question: Yes.
Sorry I'll get over it. Just annoyed cos' I was only trying to put in my legit on a topic that interests me.
Originally Posted by sbuswell
i don't think it makes a big difference, especially if you run good fuel system cleaner every 5k like I do.
On the way!
Originally Posted by Napsoner
What would be a good fuel system cleaner to use? I sometimes use STP Fuel System Cleaner, is that any good?
Originally Posted by Papa_Sean
^dude relax, he agrees with you. The sign is a joke. It just states "Im With Stupid" as in ditto I agree lol
HeloDown
09-08-2015 06:51 PM
