Why do people buy 225/40/18 instead of 235/40/18?
Yes, that's correct as it is one determining reason. But if the wheel has the proper offset to begin with, 235/35?/19 will fit. Another reason lots of people go with the 225/40/18 size is also because of selection and pricing. There are more tire selection at this size, and you could probably find something half decent if the more expensive brands don't appeal to you.
Hemants ...
225/40/18 despite it not as close to the same circumference to OEM 215/50/17 as 235/40/18 ... price and rubbing are the big issues. If you've ever seen my car after the rain, you'll see why 225/40/18 might be a better choice -- I get so much CRAP on the sides of my car (worm guts, leaves, dirt, dust, etc)
- derrick
- derrick
"hmmm i feel like and outcast here but im rolling on 215/35/18 cause my friend gave me my tires for free"
Nothing is free in this world. Those tires are 93% of stock diameter. You are losing 7% of your cars value because for every mile of depreciation, you are only getting 93% of the distance.
If you ask me, a set of proper tires is not as expensive as 7% of your cars worth!
Purchased: April 28, 2001
Keep This In Mind...tls = Not Stock
When you mean STOCK...are you referring to stock TLS or TLP wheels?
TLS = 215/50/17
TLP = 205/60/16
The TLS setup is already 0.9% faster than the TLP.
Now...a 215/35/18 tire is a whooping 6.9% faster...that means when your speedometer is reading 60mph, you are really going 55.9mph!
FYI: Acceptable difference is +/- 2.0%
TLS = 215/50/17
TLP = 205/60/16
still a Masshole
I have 225/18/40 because I couldn't find a good tire in 225/45/18 for a decent price. The selection was limited. On the other hand 235/40/18 (my preference) I thought would rub and the fact that I rub with the 225/40/18 proves I was right.
still a Masshole
Originally Posted by hemants
what wheel size and offset ferizzo?
its not bad with me and a passenger but get someone in the back or take a turn too hard and it rubs a little.
Edit: oops, didn't realize I didn't have the offset in the sig...18x7.5 with a +42 offset.
Kumho
Hey Tataweki,
What is the offset/size of your wheels? I'm seriously considering 18x7.5 on my comptech drop. What do you think?
Originally Posted by Tatewaki
I have 235/40/18 and the price of Kumho Escta is a good bargain
still a Masshole
hemants, I think if the offset is +48 you should be fine. I think its recommended that we stick between 45-52 (stock wheels I thought were a 52 offset.)
Hey Tataweki,
But the wheels I want are Axis Se7en with +42 offset.
I may end up going with 225/40/18 to make sure. Hoping i can get away with just trimming the tab and not having to roll fenders.
Hey TLS_RULZ ...
Do you really want to pay that kinda $$$ on OEM rims? I think there may be an offset issue with the 18" 3rd gen rims (need at least +45 and I think OEM 18" are less than +45...)
Go aftermarket, IMHO. (And I thought you didn't want to sink any more $$$ into your TL-S ???)
- derrick
- derrick
Hey Tataweki,
Originally Posted by TLS RULZ
Do any of you know if we can use the Acura 18" from the 04 TL's. I like em... will that go on the 02/03 Type S ? Any offset issues ?
still a Masshole
So I shaved the wheels to +45, rolled fenders and now all is great.
Peach Tea
i ran 215/35/18 for about a month or 2 and i took em off cuz every time i drove my car i thought about it adding 7 miles for every 100 miles i traveled. it sucked so i put my stock setup back on and my 225/40/ZR18 Falken Zeix 512's are in the mail as we speak
People buy 225/40 because most people buy 18"x7.5" rims. 225 is the maximum width tire you are "supposed" to fit on a 7.5" rim. Although, the 235's are the closest to the stock tire diameter.
Re: the smaller tires causing your milage to go up too fast - there's an option in the navigation system's maintenance menu that lets you change the tire size, does this only affect the nav system (and not the spedometer and milage display)?
I have 7" wheels and with 235 tires they work just fine
I know they will work fine and 99/100 people will not have problems. But if you ask wheel and tire manufacters and their distributors they will tell you 225 is the maximum recommended size.
still a Masshole
Originally Posted by derrick
Hey TLS_RULZ ...
- derrick
- derrick
It was wishfull thinking any way... My other hobby right now is going to take all my $$ for the rest of the year.
I'm running 235/40/18 on 18x8 +48 SSR GT1's with an H&R Sport drop, no camber kit, and I've got about 1mm of clearance from the metal part of the fender lip. A +42 offset with 225 tires will theoretcially stick you out 1mm more than me, so you might be able to get away with it. If you drop it, you'll definitely rub with a camber kit. To adjust my 1 degree of camber, it would push the top of my tires out about 1/4 inch . If my tires wear too unevenly, I'll probably get a camber kit and shave my fenders..
"My other hobby right now is going to take all my $$ for the rest of the year"
Yeah, studying to be a porn star is expensive but will pay off in the long run
bawhahahha
bawhahahha
still a Masshole
Yeah, I suck! I played 2v2 last night till 3am with jonesi, ted, and silver and got owned! out of five games I was only in the positive twice...although I did get MVP once! where you pato?
You :clown:
:ar15: "mrsteve fragged ferizzo..."
Just spreading the A-CL knowledge to A-TL. You all are the n00bs
bawhahahha
bawhahahha
I was on last night till around 10. Then Jonesi and Smitty got off so I did too. I'll be on tonight...
:inbeforesomeonesayswehijackedthisthread:
still a Masshole
I'll try and be on but the wife was not happy that I played for three hours...and she doesn't even know about the 4th hour! She thought I went to bed at two!!! She ownz me!
I should be on tonight but usually later, unless there is a clan match. Oh and ernie is learning the game now too. Not too bad just needs to learn the maps and his control settings!
6G TLX-S
My wheels are Motegi FF5. Original spec was 18x7 +42. With 235/40/18 it was rubbing. So I shaved the wheels to +45, rolled fenders and now all is great. With 18x7.5, I'd recommend +45 offset or higher. But even though the tire width spec is the same, some tires are slightly wider than others. I like 235 since it fits stock diameter better, and gives me more wheel protection
Tatewaki, one thing you should take notice. I've done a lot of researches before selecting my wheel/tire sizes. I don't think any tire maker ever recommends mounting its 235/40/18 tires on 7" wide wheels. You can probably get away with 7.5" wheels, but not with 7". Performance and look is good, but safety is more important.
