where to wire interior lights to door?
Old 05-29-2008 | 01:34 PM
starstruckTL's Avatar
hi, where can i wire some foot lightings so that it comes on when the door opens and closes? i dont know if i can try the dome light because it does not work at all. is there somewhere i can tap into the fusebox? if so, how? thank you in advance.
Old 05-29-2008 | 01:45 PM
c0v3rr1d3's Avatar
Depends how you want them. If you want them only straight on/off with the door, you can tap any constant power source from the passenger side fusebox. The one i would tap into is Fuse 11, you can use an add-a-circuit for this. Since fuse 11 is hot all the time and controlls the interior/courtesy lights. Then you wire the ground to each door jam, unscrew the part that presses in when the door closes and you'll find 1 wire which is your ground. Basically follow the directions to wire up the illuminated door sills if u can find it.
Old 05-29-2008 | 02:27 PM
Edward'TLS's Avatar
6G TLX-S
Tapping it from the dome light is the easiest. Try to find out why the dome light doesn't work. Another (more complicated) way is to tap into each one of the four door switches, but you'll need diodes to isolate them so that opening the rear doors won't light up the door lights on the front doors.
Old 06-01-2008 | 02:06 AM
Church's Avatar
how do you tap into the dome light? which wire is it?
Old 06-01-2008 | 02:12 AM
bibledriver's Avatar
Something is missing...my
grab a multimeter, or go buy one figure out which wire is not always hot, or always cold. it is the other one (pretty sure there will be three).
Tap into each wire, one at a time. If you run into two hot, then shut your door, then find which one is related to opening and shutting the door. That will be the one.
Old 06-02-2008 | 03:04 PM
DTPTL's Avatar
B A N N E D
can anyone elaborate please? any pics
Old 06-03-2008 | 05:02 AM
DTPTL's Avatar
B A N N E D
bump
Old 06-03-2008 | 08:40 AM
ArTL-S's Avatar
I have dead hookers in
I just removed my door panels on each front door and tapped into the courtesy lights on the door. If you use a coat hanger you can run the wires through the little rubber boot and everything is kosher and comes on when the front doors open and go off when closed
it was really not that hard at all. I also went ahead and up the fuse by 10 amps since i added extra loghts to it just to be safe.
Old 06-03-2008 | 09:05 AM
have any pics?
Old 06-03-2008 | 05:36 PM
ArTL-S's Avatar
what exactly would you like pics of? the wires i spliced, how i ran them or what? i can get you pics of anything you want man.
Old 06-03-2008 | 05:43 PM
07 TL's Avatar
plz provide pics of the wiring because im trying to do the same thing in my TL. i want my lights to come on when the courtesy lights are on. im trying to put some leds under my dash and can you also thell me what i need for the install.
Old 06-03-2008 | 06:53 PM
ArTL-S's Avatar
Ask and you shall recieve. i forgot that i changed my plan of attack while doing this and the 2 changes i made are...... i wired both the drivers side and passengers side to the courtesy light on the drivers door which is why i added a bigger fuse...... i also instead of running the wires through the boot i ran them through the same holes as the wiring harness and zip tied the wires to the rubber boot. if there are any questions after the pics just let me know. BTW the white wire is my + and the black wire is my -.....
That last picture is of the LEDs i used that i bought off ebay. i know that i didnt do it the way you might want to do it or think it should be done so if you do not like how it is done then please keep the comments to yourself.
Old 06-03-2008 | 09:55 PM
DTPTL's Avatar
B A N N E D
thats what i had, but i think its really sloppy to see when you open the doors.
Old 06-03-2008 | 10:16 PM
ArTL-S's Avatar
with the door panel on you cannot see it. the black wires are normally moved around to the back of the ruber tubing so it is not visible but left in the open i would agree with you
rockyboy
08-04-2024 11:35 AM
02-25-2020 10:57 AM
cycdaniel
12-17-2019 11:58 AM
handsom-hustla
11-13-2015 06:04 PM
pesobreeze
1G RL (1996-2004)
09-03-2015 01:26 PM
Quick Reply: where to wire interior lights to door?
