When are Major Services Due?
Hello All,
I've searched the forums but haven't found a specific answer yet.
I would like to know when major services are due on the 2G TL. I've read there is a major 105k mile service. Currently, I have a 2G TL with 143k miles and the "maintenance required" is flashing. I've read the DIY maintenance light reset so thats not a major concern.
If possible, can someone with a service schedule post the intervals for major services and what those services entail?
Your assistance is greatly appreciated.
The maintenance chart starts on page 224 of the owner's manual, which can be downloaded in pdf form here:
https://techinfo.honda.com/rjanisis/...303MAINIXA.pdf
Or if you need other than 2003, go here:
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
The links within the 1999 Acura TL pdf manual page are not working. I'm using acrobat reader 9.0 to open up the file.
Look in the manual that comes with the car
Links work for me
Links work for me
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Bleed brakes (new fluid) change power steering fluid, cabin filter , air filter , spark plugs, timming belt, water pump, change coolant.... There might be something I forgot!
the dealership wanted to to the 105k tune up witch was all that and they wanted 2300 out the door i was like holy shit is it something i can do myself???
Links work for me
Links work for me
Car was purchased w/o manual at 12x,xxx miles.
Link finally works in Internet Explorer for me, currently firefox and acrobat reader aren't working properly
Thank you all
you can do a lot of the service yourself using the DIY section on here
fluids are easy- filters too
Need to have it looked at by a mechanic that knows acura ,and see if the access covers have been off- indications the 105 was actually done for you already.
New spark plugs would be a clue as would bolts with tool marks in certain areas
Try another Acura dealer. My local Acura dealer said the 105k service included the timing belt, water pump, and some other major stuff and it costs about $850 out the door.
Pham Alvan
03-16-2016 09:17 AM
Hines57
09-24-2015 01:58 PM
