when engine oil and water mix
:( Harminder Is Lost In
when engine oil and water mix due to a bad head gasket are you screwed? it is repairable? wat could be the bad side effects due to that? its not on my tl but 02 altima
On the way!
Yes - it's repairable as long as you don't have a lot of corroson in the engine from the coolant. You'll have to get your head inspected and a new gasket put on.
It's going to be expensive unless you know how to do it yourself. I assume your 02 Altima is a 4 cyl? At least it's easy to get to. My R&R guy at the shop is going through the same thing with his old Honda (fixing it himself). Water was getting into 2 of the cylinders. He's decided to have the heads ported and polished while he's at it.
