Wheel Bearing Gone again...?
Awesome Memeber
Hey guys, as some might remember I went through a lot of trouble this past summer fixing all my wheel bearings. Now roughly 4 months later, my left front bearings are gone again! ...I will be getting it replaced tonight, but just wanted to know what could have caused the bearing to go bad so quickly? I did not hit anything like the curb or pot holes, any ideas?
Thanks,
SS
Thanks,
SS
Awesome Memeber
I don't abuse my car in the slightest, but my front wheels are slightly out of balance in the front...maybe that could have caused it? and yes AMGala my suspension is still stock, planning on lowering it in the summer
Awesome Memeber
Thanks for the replies guys, I got the bearing changed last night. My mechanic said that it had a 6 month warranty on it, so he didn't charge me. But we are still not sure what caused it to fail, it might have been defective...just to be safe though, I will be getting my wheels balanced tonight.
SS
SS
SS
SS
Awesome Memeber
The symptoms I had was a loud grinding noise which typically got louder as I went faster. The noise may change/disappear if you make a slight turn. The way I checked to see if it was engine/tranny or wheel related noise was to put the car into drive(or neutral), and hold the the brakes while giving it some gas. Hope this helps.
Ok, i have a sound that changes as I go faster as well and it is annoying as hell!!! It actually gets worse as Iturn, i have pulse on my g as pedal when I turn actually. It did help thanks for the info man. It sounds like I might have to replace the bearings. Hey how much did it run you by the way?
Awesome Memeber
I got mine changed for free as it was under warranty still, since it was only few months ago that they were installed. I paid around $150 (cdn) for one bearing when I first got it done.
at what speed did it start to make noise? or did it do it from 0mph and up?
